Overheating problem...
Old Sep 1, 2009 | 09:27 AM
  #26
rubikscube's Avatar
Default Re: Overheating issues...
Did you make sure to get rid of all the air bubbles in the lines?
Old Sep 1, 2009 | 12:45 PM
  #27
95dc2teg's Avatar
i read the other thread and couldnt find the answer to this question. Is your fan coming on at all?
Old Sep 1, 2009 | 12:55 PM
  #28
1bad-eg's Avatar
Like he said...have you even checked to see if the fans are coming on?...that's the first thing you should've checked. when the car starts to over heat watch the fans...see what they do...let us know.
Old Sep 1, 2009 | 04:36 PM
  #29
mikeSONICGSR's Avatar
I did a compression test today, here are the numbers 1-180, 2-180, 3-190, 4-190. I drove awhile today with the AC on and when I stopped the needle started going up. I know the fan doesnt come one when idleing.
Could the fan be shot?? There aren't any leaks. Or could the head be warped/cracked, or headgasket?
Old Sep 1, 2009 | 04:45 PM
  #30
Oreo-TeCk's Avatar
the fan switch that is located on the thermostat housing... first thing i would do would be unplug it and put a paperclip in the plug to jump the fans to see if the fans turn on.. if they do then the next thing i would do is change the coolant fan switch that is right there on the thermostat housing located in the back of the block that goes to the lower radiator hose...its either a 22mm or 24mm
Old Sep 1, 2009 | 05:05 PM
  #31
I jumped the switch on the thermostat housing and the fans when on, so I am confused on what switch I should replace, the one that I took out or a different one?
Old Sep 1, 2009 | 06:15 PM
  #32
Oreo-TeCk's Avatar
the switch is on the thermostat housing...u just disconnected the plug
Old Sep 1, 2009 | 06:18 PM
  #33
Oreo-TeCk's Avatar
the piece u used a paperclip to jump is the plug...the switch is on the thermostat housing...its a thermo switch that uses heat to things on and off
Old Sep 1, 2009 | 06:27 PM
  #34
mrmcnotbuff's Avatar
hey dude i had the same prob. when the car would sit at idle or low rpms the temp would start to creep up when rev up the engine the car would cool off. all it was is an air bubble in the system. where the top radiator hose goes into the head there is a little nut put water in the radiator open the nut untill it flows consistant then close it. thats all i had to do. i can send u a pic if ur still confused
Old Sep 1, 2009 | 06:30 PM
  #35
Yes send a pic, I did drain the coolant out and refilled it, then started it without the cap on, shouldn't that have taken out any air bubbles?
If I had the AC on and the fans were running and it still overheated, when why would replacing the switch matter? Just curious.
Old Sep 1, 2009 | 06:49 PM
  #36
determinedteg's Avatar
If you took out the switch on the thermostat housing and inserted paper clip and the fan turn on then its the sensor. I had the exact same problem maybe 2 weeks ago when my fan would not turn on at idle. Swapped out the sensor on the thermostat housingand it was z'allll good. Fan turned on at idle and no more rising in the temp gauge.
Old Sep 1, 2009 | 06:50 PM
  #37
"If I had the AC on and the fans were running and it still overheated, when why would replacing the switch matter? Just curious"
Actually turning the AC on would make the car overheat quicker. The heater on the other hand would help.
  #38
I am just wondering how it would make a difference if it still overheated when the fans were running wtith the AC On.
Old Sep 1, 2009 | 07:05 PM
  #39
no that will not get all the air out u need to let the air out this
Old Sep 1, 2009 | 07:59 PM
  #40
95dc2teg's Avatar
im pretty sure obd2 ls and gsr motors do not have that. Its sealed.
Old Sep 1, 2009 | 08:26 PM
  #41
I guess I will replace the cooling fan switch, even if it doesn't solve the over heating the switch is still probably bad.
Old Sep 2, 2009 | 11:18 AM
  #42
1bad-eg's Avatar
U pretty much just diagnosed the problem homie...u jumped the connector to the fan switch and the fans came on...there u go..replace the sensor.
Old Sep 2, 2009 | 05:38 PM
  #43
Well the parts store didnt have any switches so I jumped the fans with a paper clip until it gets in. I drove normally today and no overheating.
Old Sep 2, 2009 | 09:30 PM
  #44
Oreo-TeCk's Avatar
if only u would of listened the first time i said it
Old Sep 3, 2009 | 06:45 AM
  #45
Haha, yeah if I wouldnt have been an idiot and got the water pump changed, but atleast there is a new one in there since I dont know when they did it last.
Old Sep 3, 2009 | 02:12 PM
  #46
Well I thought the problem was solved, but when I was sitting in traffic today it started to go up. It definitely was an improvement from before but still... I only have water in the radiator right now, no antifreeze, could that have something to do with it?
Old Sep 4, 2009 | 05:35 AM
  #47
Since I am still having the problem, I am going to get a new rad cap, I am trying to avoid doing the headgasket until the last thing.
Old Sep 4, 2009 | 12:39 PM
  #48
sixfourkiller's Avatar
Default Re: Overheating problem...
Originally Posted by mikeSONICGSR
Put on the OEM seals and took care of that problem. Hopefully I can start the head gasket this weekend. And also try a compression test.
One question though, if my head gasket is blown wouldn't I be smoking all the time, the only time it smoked is right after we changed the thermostat and added water? No smoke since then...
yeah the oil in your spark plugs is the valve cover gaskets they come also with 4 gasket for your spark plugs. and about the smoke yes that is true but not all the time u can have a blow gaskets without having heavy while smoke coming out the back.
Old Sep 4, 2009 | 12:44 PM
  #49
Also did a compression test, the numbers were 180, 180, 190, 190, would they be that good if the head gasket was blown?
Old Sep 5, 2009 | 01:46 PM
  #50
oops my bad
