Overheating issue
Old Aug 1, 2014 | 11:38 AM
slow_low_eddie's Avatar
Default Overheating issue
Alright so I noticed that when it's ridiculously hot outside and I am in one spot too long my car will overheat. I put on the heater and it cools down. I also notice that my idle goes up and down and the AC will get warm and then bam, it starts to overheat, does that often happen?
Fans work, I'm going to double check on the thermostat today.
Just wanted some other ideas from fellow members.
1991 Integra b18a1
Thanks.
Old Aug 2, 2014 | 09:04 AM
tamboo's Avatar
10 Year Member
Default Re: Overheating issue
bad rad cap, bad timing, stuck thermo, water pump, clog, fan, etc.
see section 10:
http://www.spooledupracing.com/downl...als/FSM/Honda/
Old Aug 2, 2014 | 09:23 AM
Originally Posted by tamboo
bad rad cap, bad timing, stuck thermo, water pump, clog, fan, etc. see section 10: http://www.spooledupracing.com/downl...als/FSM/Honda/
Fans are working, forgot to mention radiator and cap are new since my old one was leaking a bit from the drain plug. There really isn't a way to check the water pump right? I'll have to check on the thermostat, I want to stay both top and bottom hose get hot once it's warmed up, I'll have to double check.
Flipmonkey
Sep 30, 2013 06:54 PM
DumaDA
Jun 25, 2011 12:50 PM
eg8guy
Nov 2, 2008 12:21 PM
brewerdude
Jan 8, 2006 06:31 PM
Accord_Munch
Nov 13, 2002 06:12 AM
