overheating
Old Apr 9, 2007 | 01:36 AM
dohcgarage@714's Avatar
Default overheating
hey guys whats up i need your expert advise my car has been over heating at first i thought it was the thermostat because water wouldnt circluate so i changed it but its still over heating anybody have any ideas?????
Old Apr 9, 2007 | 03:58 AM
Tizight's Avatar
Cooling fan?
Are you burning coolant?
Leaking coolant?
Old Apr 9, 2007 | 10:23 PM
Default Re: (Tizight)
no im not buring coolant and my fan works
Old Apr 9, 2007 | 11:32 PM
__oversea's Avatar
Default Re: overheating (dohcgarage@714)
overheating when you are at stop or going.
Old Apr 10, 2007 | 12:42 AM
Fo-Do Fanatic's Avatar
Default Re: overheating (Kangpreza)
how much flud do you have in the radiator? is it overheating when you are moving or stopped?
Old Apr 10, 2007 | 01:19 AM
jjzend600rr's Avatar
Head gasket...if you keep adding radiator fluid and don't know were it goes its your head gasket....
do this....
let your car cool down, once your engine is cold and can take the cap off the radiator keep it off...now turn on the engine with the radiator cap off....once you turn on your car check inside the radiator and see if the water/fluid is circulating..now you said the thermostat is off....so it should circulate right away...now if you are not sure what the heck is doing...reach for the throdle cable and give it some gas...not to much though or fluid can spit out..give it gas slowly and take a good look at what happens inside your radiator...your fluid should start to move from left to right, you should see a flow...now if thats not happening then it's your water pump...its not circulating ...now keep in mind that the thermostat is off...so it should have no problem circulating...now one more thing it might be if its the original radiator..then it could just be plugged up...not all off it but some were in there its not flowing well.....but most likely it can be your water pump if it does not circulate..if its fine and you see fluid running freely and you just keep over heating...sorry mang...but it could be a blown head gasket...some were in there there is a small leak going into your combustion chamber..and chining up your pistons...if you see white smoke coming out of your tail pipe when you give it gas ...then thats it...also check you OIL cap......take it off..if you see milk dots at the inside part of your oil cap ...then thats water going into your oil...and it could cause it...mmmm other thing to check is your oil...make sure there is oil in there...if there is...make sure is circulating...now to check that..turn on the engine...take the oil cap off...yes..off when the engine is on...but slowly lif once is loose...now grab a towel or something because it might spit some oil out but not much if its at idle...if you see oil coming out of your vavle cover oil cap hole and can see oil spalahing then its fine...if you cant ...give it some gas...again...be carefull...at it might splash a little..if its not splashing...then your oil pick up line on the oil pan might be clogged up a little....thats it all the advice I can give....sorry for the long write up..good luck..
Old Apr 10, 2007 | 01:20 AM
Default Re: (jjzend600rr)
edited for dumbassness
Modified by b00sted-Hatch at 2:35 AM 4/10/2007
Old Apr 10, 2007 | 01:25 AM
what the hell are you talking about...if you are an idiot and not care full then yes you deserve to go blind...****...then wear some PPE
Old Apr 10, 2007 | 01:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jjzend600rr &raquo;</TD></TR><TR><TD CLASS="quote">what the hell are you talking about...if you are an idiot and not care full then yes you deserve to go blind...****...then wear some PPE</TD></TR></TABLE>
ahaha my bad bro. ill edit the post. i forgot about protective eye wear. im a noob, you owned me. i bow to you sir
Old Apr 10, 2007 | 01:55 AM
Default Re: (b00sted-Hatch)
no problem...its cool...ggrrrrr..jk..
Old Apr 10, 2007 | 05:00 AM
Th3savinday's Avatar
air bubble in system?
Old Apr 10, 2007 | 05:01 AM
teggyracer91's Avatar
yea deffinetely the head gasket i just recently had the same problem. the middle layer of the gasket was broke between two cylinders. so water was leaking through it. but now the car runs great.
Old Apr 10, 2007 | 02:15 PM
Default Re: (teggyracer91)
its not my head gasket because my coolant is there but when i drive my car and step on it thats when it starts to overheat and when i touch my radiator hoses the bottom one is cold and so is the bottom part of my radiator but the top hose is hot as hell and really hard all my coolant goes into my overflow tank
Old Apr 10, 2007 | 02:17 PM
Default Re: (dohcgarage@714)
your radiator is probably bad then. if one hose is hot and the bottom is cold then there HAS to be a blockage in the system. get yourself a new radiator. or it could deffinitally as wel be your water pump
Old Apr 10, 2007 | 02:19 PM
thewrai6th's Avatar
Top hot, bottom cold, new thermostat...No circulation...
Water pump?
Old Apr 10, 2007 | 04:16 PM
BacardiBreezer's Avatar
Default Re: (thewrai6th)
+1 on the water pump
Old Apr 10, 2007 | 06:59 PM
like I said...
Old Apr 10, 2007 | 08:41 PM
liftedresearchgroup's Avatar
i would have thought the fan too
Old Apr 10, 2007 | 08:48 PM
brokengsr01's Avatar
had the same probably and so i got a new radiator... it solved my problem
freshgear
Jul 19, 2009 01:48 PM
szczerbanator
May 31, 2009 08:28 AM
just4747
Dec 8, 2004 12:45 PM
92VtecTeggy
Jun 20, 2003 08:13 AM
PearlWhiteAccord
Sep 25, 2002 12:15 PM
