overheating
Old Dec 29, 2005 | 05:21 PM
sgergg454's Avatar
Default overheating
i have a 90 integra gs and it keeps over heating. it fine when i am driving but when i am at a stop light for longer then 15 second it starts to over heat fast. while i am at the stop light i rev the motor to 2000 rpm and it normaly stays cool. i already fix the thermastat and the rediator is only 4 years old....any one have any ideas to fix this probleme? anything help would be nice
thank you
Old Dec 29, 2005 | 05:24 PM
numbnuts22715's Avatar
have you checked the coolant level in the radiator?
it doesnt matter how old it is.. it oculd still be leaking.
Old Dec 29, 2005 | 05:26 PM
sgergg454's Avatar
Default Re: (numbnuts22715)
its not leaking and i did a pressure test on the radi and radi cap
Old Dec 29, 2005 | 05:34 PM
possibly your head gasket?
Old Dec 29, 2005 | 05:36 PM
sgergg454's Avatar
dang i hope not...i was hoping it was maybe a water pump or a cloged raidiator?
Old Dec 29, 2005 | 05:39 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: overheating (sgergg454)
Is your fan working?
Old Dec 29, 2005 | 05:40 PM
sgergg454's Avatar
Default Re: overheating (Dogginator)
dang i left a bunch of stuff out...yes the fan works
Old Dec 29, 2005 | 05:42 PM
Dogginator's Avatar
Daisy... Daisy...
Air pockets in the cooling system? Did you bleed these when you changed your coolant?
Old Dec 29, 2005 | 05:43 PM
sgergg454's Avatar
yes ...there was screw and when it leaked water a closed it up
Old Dec 29, 2005 | 05:44 PM
juicy629's Avatar
if it cools down when you accelerate is cuz your thermostat is opening up.. its your thermostat.. more then likely..not enuf anti freeze.. so it got stuck.. check your coolant/water ratios
ADIZZLE08
Honda Civic (2001 - 2005)
13
May 11, 2010 08:15 PM
EM88
Jul 21, 2009 03:12 AM
Nameless Warrior
10
Dec 16, 2006 07:27 AM
mR. Vash
Aug 20, 2004 04:46 PM
Gabe_
12
Jun 13, 2003 02:47 AM
