Oil problem? help
Old Mar 19, 2003 | 11:06 AM
blkgsr03's Avatar
Default Oil problem? help
sometimes i check my oil level and it goes down. wut could be the problem.i have to keep adding oil to keep up with the dipstick level. i got a new oil pan and seeems like everything is ok. there is not a leak anywhere. wut could be the problem?
Old Mar 19, 2003 | 11:12 AM
NeoGSR's Avatar
Default Re: Oil problem? help (CiViC KiD)
it could be that you are burning oil caused by bad rings (blow-by)
it could also be that the engine is sucking oil in through the pcv
do a compression/leak-down test to determine whether it is the rings....
soundFX
Jan 7, 2007 05:53 PM
20_00_lude
Apr 12, 2006 10:08 AM
SPRLude
Apr 6, 2006 08:18 PM
SIK IN DA HED
Jun 23, 2001 07:57 PM
