OIL Light question/problem
Old Apr 6, 2009 | 02:56 PM
MonsterB20Ek's Avatar
Default OIL Light question/problem
ok this is weird to me
i just swapped in a 1995 B18b1 into my 1997 integra ls
started right up no problems what so ever about 20 min. later
i let the car run the oil light started to blink so i turn the car off
and check everything (new oil so oil level is good) i put a new oil
pressure switch and turn it back on same thing about 20 min. later
the light starts to flicker and so i turn the car off and right back on
and the light stays off for another 20 min. over and over again
i took off the oil pump (bought a used but good one from a friend)
when i took the one off the car i pulled it apart and it looks better
then the one i bought so i put the old one back on.
changed my ecu and i put thicker oil in there also and no change weird
thing is when the light turns on i restart the car and it takes it 20 min. to turn on again.
if anyone can help me with this i would appreciate it just thoughts you
might think is wrong with it so i can check it out
Old Apr 6, 2009 | 05:51 PM
j_bizach's Avatar
Default Re: OIL Light question/problem
well first id say run an oil presure test on it see if when the light comes on the oil presure drops if its good mite be a bad sending unit.
Old Apr 6, 2009 | 06:21 PM
EARLdaSQUIRREL's Avatar
official honda whore
put an oil pressure gauge on it, simple easy solution to find out if its the pressure or just a wiring problem
Old Apr 6, 2009 | 06:27 PM
stocker2shocker91's Avatar
I requested a short story for a title.
if you got good level then i would guess its an electrical problem. since you just swapped the motor you could have easily missed something..
i would check the wires first
Old Apr 6, 2009 | 08:32 PM
thnx for the replys
wiring should be good because for the first 20 min. at a time
nothing is wrong until it flickers.
and yea i was thinking of putting a oil pressure gauge in to know
for sure if its getting low pressure when its flickering/on
any more thoughts on what it could be? just so i can fix it for when
i put the gauge in there and nothing is actually wrong
Old Apr 7, 2009 | 07:53 AM
i would put a guage first just to make sure its not something mechanical
Old Apr 7, 2009 | 08:04 AM
Top Speed's Avatar
Without doing an oil pressure test. You really are going to have tough time finding the problem.
Raleigh21native
Apr 27, 2018 02:03 PM
slow_low_eddie
Apr 17, 2014 06:01 PM
Homesickelian
Jul 28, 2007 07:10 PM
hillsidedrill
Jul 19, 2007 06:48 PM
notstock93
Dec 23, 2004 02:13 PM
