oil light issues
okay so i have a 92 LS from which i parked for the winter, and i went out to start it to keep the battery charged and my oil light stayed on after start up, it was more like a dim light instead of a full light, and i know this because right before the light went off it flashed about 5 times at "full brightness" i guess and then it went away.
once it goes away but doesnt come bak, but if i start it again it'll come on dim again and then eventually fade out.
so i gave it an oil change, cuz it needed it. and its still doin it...is my oil pump wearing out? or is it the oil sensor on the back of the block going bad? or anything else?
thanks in advance.
thanks in advance.
Check out the suggestions provided to someone with a similar issue in this recent topic.
Homesickelian
Jul 28, 2007 07:10 PM
