vtec not working
Old Jan 11, 2008 | 12:31 AM
kenny7231's Avatar
Default vtec not working
just noticed my vtec is not working.. any suggestions wat it could be? there is no cel on and i know check engine lights works.... wat u thinkmy problem is?
Old Jan 11, 2008 | 04:41 AM
kenny7231's Avatar
also car oil is full and was just changed 1k ago
Old Jan 11, 2008 | 04:56 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: (kenny7231)
Mods? Car? ECU?
Does your speedo work? Is the car up to operating temp when your trying to hit mad vtak?
Old Jan 11, 2008 | 05:09 AM
kenny7231's Avatar
only mod is an intake other than that its completly stock, yes my speedo works and im guess it was about 55 degree when i tried to hit vtec.. car was already warmed up tooo
Old Jan 11, 2008 | 08:40 AM
96lsvtec18's Avatar
Sounds pretty weird... you said you changed the oil.. but is it the right amount in there? ecu chippped? if it is cel doesnt work... but def check the wiring to the vtec solenoid mayb take it off clean it out might be clogged
Old Jan 11, 2008 | 08:44 AM
jhammond_82's Avatar
Reject Papi
Default Re: (96lsvtec18)
yeah, maybe the solenoid took a ****, do the "light" test and see if it engages.
Old Jan 11, 2008 | 09:07 AM
kenny7231's Avatar
if i take the solenoid out can i still use same gasket for now?
Old Jan 11, 2008 | 12:55 PM
St Jimmy's Avatar
* B A N N E D *
Yes you can use the same gasket. You can test if its your solinoid by sending 12v to it while driving and see if it kicks on. If it doesnt kick on then its your solinoid, if it does kick on the its the wiring. If its the wiring I would run a new direct wire from the solinoid to the ECU.
dwils
Oct 28, 2012 11:04 AM
Vtecruddy
Mar 17, 2011 03:41 PM
GraphiteMW
Dec 11, 2010 02:39 PM
MOST
11
Feb 28, 2007 01:29 AM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
