OBD2-OBD1 Conversion...TACH doesnt work
Old Aug 22, 2007 | 10:41 PM
Japostol78's Avatar
Default OBD2-OBD1 Conversion...TACH doesnt work
whats up....doin the obd2b-obd1 conversion on my 01 Integ LS...swapped in a 98 B20B motor...reason for the the conversion is to get rid of the CEL light due to the oil sensor pump not connected....
Anyway...two things I noticed after doing the conversion...
1. My tach doesnt work at all...speedometer works...but no tach signal at all.
2. When I start the car...it sounds like its dying...trying to stay on...does this till it warms up and its fine
Any help to solve these problems would be appreciated...i solved my CEL light problem...now these...
Old Aug 22, 2007 | 11:42 PM
Mfoehrkolb's Avatar
OBD1 to OBD2 Step-up
============== EBAY! Check it Out! like 50-75$
OBD2 to OBD1 Stepdown
Cheap and Clean
Old Aug 23, 2007 | 02:29 AM
mtber's Avatar
Default Re: (Mfoehrkolb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mfoehrkolb &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 to OBD2 Step-up
Cheap and Clean</TD></TR></TABLE>
Ebay conversion harnesses fall apart. I don't know how many times I have had to sell tuning customers one of our harnesses b/c theres had loose pins. You get what you pay for in the automotive industry.
Concerning the original post. It sounds like your issue is in your conversion harness.
Old Aug 23, 2007 | 02:59 AM
Mfoehrkolb's Avatar
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
--- haha might fall apart but hey it works for a bit
Old Aug 23, 2007 | 05:24 PM
Japostol78's Avatar
Default Re: (mtber)
the harness i got is from ebay....if i got a phearable....skunk2...or jdmshit harness...i wouldnt have this tach problem?? what can i do on the harness i have to make the tach work???
Old Aug 23, 2007 | 07:02 PM
mtber's Avatar
--- haha might fall apart but hey it works for a bit </TD></TR></TABLE>
Whats the point then ?
Your spending $50 on a total pos vs $25-30 more on a nice unit.
Old Aug 23, 2007 | 07:06 PM
mtber's Avatar
Default Re: (Japostol78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Japostol78 &raquo;</TD></TR><TR><TD CLASS="quote">the harness i got is from ebay....if i got a phearable....skunk2...or jdmshit harness...i wouldnt have this tach problem?? what can i do on the harness i have to make the tach work???</TD></TR></TABLE>
Possibly
Old Aug 23, 2007 | 09:00 PM
CompanyFlow's Avatar
The money you would spend to modify the harness you have now could be easily spent purchasing a quality harness without having to shell out anymore cash in the future.
Old Aug 23, 2007 | 09:16 PM
Japostol78's Avatar
Default Re: (CompanyFlow)
good point...i'll try the phearable harness out...thanks for the input guys....
Old Aug 23, 2007 | 09:19 PM
I aim to please.
Old Aug 25, 2007 | 05:46 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
i actually had the same problems too. its not your harness! i had a buddy that had the same problems and went thru 4 different harnesses like skunk2 and phearables one. i solved the problem for the both of us with the tach...
the OBD2b ECUs send the tach the signal, not the distributor like OBD2a and OBD1. the engine's harness is missing the tach wire from the distributor to the shock tower. run the one wire at the distributor that has no connection on the engine harness side to the blue wire at the driver's shock tower.
and as far as the bouncy idle, im in the process of solving that problem too which is how i came across this thread on the search engine, it might have to do with how OBD2 throttle bodies dont have a FITV (located underneath the OBD1 throttle bodies that work with the IACV to maintain idle on OBD1 ECUs) since OBD2 throttle bodies dont have FITV and the obd2 ECU only uses the IACV to maintain idle, an OBD1 conversion might cause the problem with the idle because there is no FITV on a OBD2 throttle body. i will let you know if i solve that problem
Old Sep 2, 2007 | 06:56 PM
Japostol78's Avatar
Default Re: (JDM turbo DC)
thanks for the reply....i ended up gettin a phearable conversion harness...and everything works fine...only thing is the jumpy idle at startup...thats my only problem now...i think its just cuz it doesnt have the FITV...thats the only thing i can think of...please do fill me in though if you solved that problem...
Old Sep 2, 2007 | 07:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Japostol78 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the reply....i ended up gettin a phearable conversion harness...and everything works fine...only thing is the jumpy idle at startup...thats my only problem now...i think its just cuz it doesnt have the FITV...thats the only thing i can think of...please do fill me in though if you solved that problem...</TD></TR></TABLE>
its not the FITV because when obd1 motors replace the intake manifold, the aftermarket manifold doesnt have FITV and there arent any idle problems. i will let you know if i can figure it out
Old Sep 3, 2007 | 12:48 PM
Japostol78's Avatar
ok cool..let me know...already tired of this idle problem
Old Sep 3, 2009 | 11:36 AM
Muckman's Avatar
Moderator in Chief
Default Re: OBD2-OBD1 Conversion...TACH doesnt work
Im having the same problem. '00 GSR. OBD2b to OBD1 adapter harness with OBD1 P72. Tach doesnt work but does work when stock ecu is plugged in. Adapter harness is a good unit from Xenocron. The adapter harness has A19 (engine pulse) spliced with B13 (ignition control module) on the engine harness plug. I think this splice is supposed to support the tach signal.
Can anyone confirm this? Or is the adapter harness not designed to address the tach problem at all?
Old Sep 10, 2009 | 12:25 PM
Muckman's Avatar
Moderator in Chief
Got replacement harness. Tach still does not work. Tach works when stock ECU is plugged in. Need help.
axtran
May 9, 2006 08:27 PM
brotech
Dec 20, 2005 08:02 AM
stevieteg
May 17, 2004 11:35 AM
LS stretch
Jan 25, 2004 12:51 PM
scoobyghost
Apr 26, 2003 04:38 PM
