obd1 conversion problems!
Old May 26, 2003 | 02:16 AM
allmotortypegsr's Avatar
Default obd1 conversion problems!
I have a 2000 gsr and I bought the harness, and an obd1 p72 ecu to jump it to an obd1. I plugged everything and my check engine light turns on and reads iacv problem. Also the idle is at 500 and fluctuates from 400-500 rpm. Is this normal?
Old May 26, 2003 | 01:04 PM
00VTEC's Avatar
Default Re: obd1 conversion problems! (allmotortypegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotortypegsr &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2000 gsr and I bought the harness, and an obd1 p72 ecu to jump it to an obd1. I plugged everything and my check engine light turns on and reads iacv problem. Also the idle is at 500 and fluctuates from 400-500 rpm. Is this normal?</TD></TR></TABLE>
i don't have a definite answers to your questions but here are couple of links. i hope it helps.
https://honda-tech.com/zerothread?id=183609
https://honda-tech.com/zerothread?id=463616
vtec-adykt
Apr 14, 2007 10:42 PM
yeegsr
15
Apr 3, 2006 06:36 PM
B18 CYA
Jun 1, 2004 11:22 AM
bbb18c1
Jan 12, 2003 01:40 PM
