HID problems
Old May 24, 2003 | 12:37 AM
MachAF's Avatar
Default HID problems
I have a set of McCulloch 9006 6000k HIDs. The left side has issues. It takes it 30 seconds longer than the right one to start the warm up phase (left side not even on). Now I do a long drive with them at night. And the left side starts going on and off. Then it totally goes off. I checked all the connections they look good. I replaced the 10amp fuses with 20amp ones the other day. I'll check for a blow fuse in the morning. Any one have any ideas?
I got this kit off ebay for $225, so it guess it was too good to be true. I'm asking the seller for my money back if I can't get this worked out.
Old May 24, 2003 | 01:35 AM
nek0's Avatar
Default Re: HID problems (MachAF)
Did you try to swap the bad bulb with the other ballast? Try & check, if it keeps happening, you got a bad bulb.
Old May 24, 2003 | 03:23 AM
Holly35's Avatar
Mine did that too. Never knew why....I ran a 25A fuse in there on a 8000k kit and it still shorted in one side sometimes.
Old May 24, 2003 | 09:20 AM
MachAF's Avatar
I switched everything around, changed bulbs, changed ballasts. Still does the delay thing. So I assume its bad ballast. I opened up the ballast. Nothing I can do, its a filled with black sealant stuff.
Anyone got any ideas? Anyone know McCulloch's #? Their website is down and I dont have instructions.
Old May 24, 2003 | 11:57 AM
split's Avatar
connect a relay from your battery to the ballast....that will draw less current and you'll only need a 30a fuse
Old May 24, 2003 | 01:18 PM
MachAF's Avatar
Default Re: (split)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by split &raquo;</TD></TR><TR><TD CLASS="quote">connect a relay from your battery to the ballast....that will draw less current and you'll only need a 30a fuse
So how will this solve the one ballast not working correctly problem? It still doesn't work correctly even when its the only one connected.
Old May 25, 2003 | 04:07 PM
nek0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">I switched everything around, changed bulbs, changed ballasts. Still does the delay thing. So I assume its bad ballast. I opened up the ballast. Nothing I can do, its a filled with black sealant stuff.
Anyone got any ideas? Anyone know McCulloch's #? Their website is down and I dont have instructions.</TD></TR></TABLE>
I would never open the ballast...those capacitors if shorted can blow in your face. Are you sure you tested the bad bulb with both ballasts? Does the good bulb turn on slow with this suspected ballast? If you can't contact them I'd try getting Philips ballast.
Old May 25, 2003 | 05:38 PM
ebelp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">I switched everything around, changed bulbs, changed ballasts. Still does the delay thing. </TD></TR></TABLE>
Kind of hard to follow what you did. Did the problem follow the bulbs or the ballasts? Does the same side always have a delay? More specific please.
Old May 25, 2003 | 10:29 PM
MachAF's Avatar
Default Re: HID problems (ebelp)
its a problem with the ballast/ignitor unit. Its getting worse as time goes on. Bulb won't stay on more than a few mintues now before the ballast turns itself off.
new ballast for me i guess.
Old May 25, 2003 | 11:38 PM
M-Type's Avatar
is this a common problem? i was planning on gettting this kit soon, so is this a common problem with the old mc culloch 6000k series?
Old May 26, 2003 | 12:53 AM
marmaladedad's Avatar
Default Re: HID problems (M-Type)
I have the G-Garage/McCulloch HID kit (4300k) on my Integra, and I have had NO problems whatsoever. Mounting was kinda tricky, and I accidentally nicked my hood, but otherwise it's been great. Had it since February.
Modified by marmaladeboy at 9:40 AM 5/26/2003
Old May 26, 2003 | 03:05 AM
nek0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">its a problem with the ballast/ignitor unit. Its getting worse as time goes on. Bulb won't stay on more than a few mintues now before the ballast turns itself off.
new ballast for me i guess.</TD></TR></TABLE>
What does your bulb/connector look like? Unless you can find a used Philips ballast like on eBay it's more cheaper to just buy a new kit. New ballasts runs about $150 retail.
I do see a pair of ballasts on eBay for $229...I almost want to say just get a new 4100K kit (for the brightest) or 6000K at the most (for the slight purple/blue color).
Old May 26, 2003 | 07:28 AM
ebelp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M-Type &raquo;</TD></TR><TR><TD CLASS="quote">is this a common problem? i was planning on gettting this kit soon, so is this a common problem with the old mc culloch 6000k series?</TD></TR></TABLE>
I've never heard of specific problems with this type of kit. Maybe it's just a dud ballast. IMO, the Philips and Catz kits are the most reliable.
Old May 26, 2003 | 09:31 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
In this case scenario, I would have to say RELAY.
Many kits come without relay which for some reason causes yor hids to go on and off while you are driving.
With a relay, it solves the problem! and lets you turn your hids on and off without any problems
Old May 26, 2003 | 01:33 PM
MachAF's Avatar
Default Re: HID problems (MugenHonda)
McCulloch kit is top notch. Its just I bought it used from some guy on ebay. I paid $225 for the kit. Then I told him the ballast was broke and he sent me $150 to replace it. So basically I paid $75 for the HID kit. Only ballasts like McCulloch ballasts are BOHMEN.
I'm not sure a relay will even solve this. Its just a bad ballast.
thx for the help everyone.
kjg8erz8
Aug 1, 2006 11:50 AM
s2000june
Apr 27, 2005 02:19 AM
b18bEG
30
Dec 13, 2004 05:26 PM
speedymon
Nov 19, 2002 11:28 AM
