OBD HELP PLEASE!!!
Old Feb 8, 2010 | 07:29 PM
megamanx057's Avatar
Default OBD HELP PLEASE!!!
Hi,
I recently put a b18b1 into my 95 dc2
the car starts up and runs but idles a little funny and sometimes bogs out.
I am running a p75 obdI
I think my 02 sensor is bad and there is a crack in the headers.
I was wondering what could cause the funny idle and bogging out.
also my tach doesnt work and I have two plugs that dont seem to fit anywhere
do I need to change my ecu and get a jumper harness?
please help
thanks
Old Feb 8, 2010 | 07:36 PM
slomofo's Avatar
GDD Member
Default Re: OBD HELP PLEASE!!!
Why is this OBD related? You put an OBDI engine with an OBDI ECU into an OBDI car.
Snap pictures of the plugs that you can't figure out and fix your exhaust leak. A big exhaust leak will usually throw a code for O2 Heater.
Edit: Is it a DC2 or did you just pull that chassis code out of your ***? If it's a DC2, the two extra plugs are probably for VTEC.
Old Feb 8, 2010 | 07:55 PM
yeah I guess I did pull it out of my ***...
its a 95 RS
someone told me the b18b1 was obd2... so I'm confused.
the car had a b20b jdm which I am also the impression is obdII
the dizzy wires were all spliced up... I thought this had to do with the OBD difference
If I hook up the dizzy that the b18b1 came with it does not start. these wires are not cut.
but when I hook up the b20 dizzy with the spliced wires it starts...
I am so lost with the obd stuff. i thought it was obdii cause it worked with the old dizzy
Old Feb 8, 2010 | 08:08 PM
here are the two plugs and a hose... where do they go?
Old Feb 8, 2010 | 08:13 PM
slomofo's Avatar
GDD Member
What color are the wires on the second 2-pin plug?
Old Feb 8, 2010 | 08:25 PM
the wires in the second pic are
dark green with white stripe
and
light blue with white stripe... it might have been light green
Old Feb 8, 2010 | 08:58 PM
sovada's Avatar
one reason it idles funny could be that tube coming off the intake that doesnt have a vacuum hose to the manifold or it isnt capped off
Old Feb 8, 2010 | 09:04 PM
where is that hose suppose to connect to?
I can just cap it off?
Old Feb 8, 2010 | 09:06 PM
sovada's Avatar
if all the hoses are hooked up then i would just take a vacuum cap and cap it off.
does it idle funny all the time or just when its cold??
Old Feb 8, 2010 | 09:13 PM
when its cold! those rainy days were the worst
Old Feb 8, 2010 | 09:17 PM
sovada's Avatar
hmmm... then i wouldnt really suspect a vacuum leak to be honest.
when the motors warm and its not doing it anymore, lightly sprak carb cleaner around.
i know it sounds dumb but its an easy way to find vacuum leaks. but it sounds more like your iac valve since its bogging out
Old Feb 8, 2010 | 09:35 PM
cool, thanks for the help
I'll plug the hose and get some new headers, if that doesnt work i'll go get a new iac and o2 sensor
Old Feb 8, 2010 | 09:38 PM
slomofo's Avatar
GDD Member
That hose doesn't do anything as far as idling goes, it's the one that connects to the valve cover.
Old Feb 8, 2010 | 09:41 PM
o yeah my tach doesnt work anymore... what plug would that be?
Old Feb 8, 2010 | 10:38 PM
slomofo's Avatar
GDD Member
Did this car or harness used to be automatic?
Old Feb 8, 2010 | 11:02 PM
i'm pretty sure the car was manual from the start
I know the b18b was originally hooked up to an automatic trans and I used its engine harness.
should I switch it with the b20 engine harness?
demo024
Engine Management and Tuning
Jan 31, 2011 06:33 PM
Buitrex
Apr 11, 2004 09:31 AM
TS4L
Mar 12, 2004 10:33 AM
chris81
Feb 22, 2004 12:05 PM
fluke702
Sep 24, 2001 08:27 AM
