nuts and bolts
Old Sep 21, 2009 | 07:25 PM
jlfrnce's Avatar
Default nuts and bolts
ok, first off i dont need ur sarcaism, it wont help me, but i know, i used cheaps bags for my nuts and bolts and almost all of them are every where now in 1 tub, baggies ripped/split. and info on what goes where i managed to put most of them on a magnetic try but any info to find out what goes where? my car has been down for almost a year now so i also forgot!
Old Sep 21, 2009 | 07:46 PM
egsleepercivic's Avatar
Default Re: nuts and bolts
if you tell us what you took apart it will be easier for us to tell you which bolts you need
Old Sep 22, 2009 | 03:31 AM
jlfrnce's Avatar
i rebuilt the whole motor, i got the oil pump on and the rear main seal, motor on the stand still, and i have the coolant tube on also and pcv box also, not much to go on tho
Old Sep 22, 2009 | 10:22 AM
9KRevLimitDC2's Avatar
If you have access to a helms manual I would refer to it for everything you put back together. When doing so, reference each bolt required for each location with the size the manual states. Ex. (10x1.25mm). Your going to need some way of measuring the size of each bolt (mostly length) to make sure you don't use a bolt with the right thread but wrong length. Its going to take a while but be patient. Theres plenty of resources that have diagrams of the correct nuts and bolts. Good luck
Old Sep 22, 2009 | 10:28 AM
mouab18c1's Avatar
just look for a diagram showing the bolt sizes and where they go
Old Sep 22, 2009 | 05:15 PM
Maluko's Avatar
Old Sep 23, 2009 | 10:54 AM
jlfrnce's Avatar
Thanks
SIRIUS VTEC
11
Aug 19, 2010 09:37 AM
invisible
Welding / Fabrication
Apr 12, 2009 08:26 AM
paulzy
11
Dec 3, 2007 12:43 PM
Historyg
Nov 27, 2007 02:49 PM
shutta
Jan 20, 2006 10:35 AM
