not starting SOLID CELL help
Old Mar 31, 2009 | 03:39 PM
teknohatchie91's Avatar
Default not starting SOLID CELL help
Hi my car is giving me a solid cell and is not reading any codes anymore. is just straigh solid with no blinks or nothing. and my car tries to star but it just cranks over and doesnt fire up. My ecu is bad right? if so what ecus could i use for my 93 integra ls. checked for fuses,grounds, mainr relay, everything possible and could not find the prob, so im pretty sure it my ecu since its giving me the code for it.ok thanks
Old Mar 31, 2009 | 04:16 PM
Default Re: not starting SOLID CELL help
help some one? i also reset the ecu multiple times.
Old Mar 31, 2009 | 05:04 PM
anyone?
Old Mar 31, 2009 | 06:03 PM
some 1s gotta know
Old Mar 31, 2009 | 10:22 PM
my_hidden_romance's Avatar
check the 15a ecm fuse in the engine bay...if its good....replace ecu...use the code on the ecu to find a replacement
Old Apr 1, 2009 | 02:08 PM
checked for fuses,grounds, main relay, everything possible and could not find the prob
Old Apr 1, 2009 | 04:49 PM
**** this pos intergra im ready to junk the mother****er
Old Apr 1, 2009 | 09:33 PM
dump3deg6's Avatar
if its throwing a SOLID code.. That means ECU failure.
Get a new ecu and your good
As far a which ECU to use, you can use the same one that came out of the car. Look on the side of the computer and it will say which one it is. It will start with a "P".. Like P75 (obd1 ls)..
Best of luck!
Old Apr 1, 2009 | 11:51 PM
Best of luck!
thanks bro ur a good guy
heredago
14
Jan 14, 2007 09:41 AM
Camshaft
Aug 4, 2004 03:09 PM
kim_2_da_chee
May 30, 2003 06:18 PM
Red_Si
Apr 29, 2003 10:27 AM
