Non-stored check engine code, sputtering....??
Old Jul 16, 2008 | 08:12 PM
xkevox's Avatar
Default Sputters when cold, check engine light that turns off after minutes.
Whats up guys... I have a 96 Teg GS-R with Moates OBDI setup and a Jackson Supercharger installed @ 6 psi. My check engine light comes on sometimes when i start the car for the first time of the day. So far, I've replaced spark plugs, wires, distributer cap and rotor were replaced fairly recently, ignition coil, fuel filter and fuel pump....I've also tried two different Main Relays...
other symptoms are if i step on the accelerator (with or without the check engine light), the car will get up to about 2500 rpm's and start sputtering and sounds horrendous. This only lasts a few minutes before the check engine light turns off(if it came on in the first place) and the car runs seemingly normal. any ideas??
Modified by xkevox at 6:20 PM 7/23/2008
Old Jul 23, 2008 | 05:18 PM
xkevox's Avatar
Default Re: Non-stored check engine code, sputtering....?? (xkevox)
anyone?? anyone at all???
91accordflow
Jun 6, 2009 05:12 PM
alfiler
Feb 16, 2009 11:55 PM
Ed 341
Mar 8, 2006 02:45 PM
jvcnyc
Jun 2, 2004 06:23 PM
918-Hatch
May 20, 2004 09:44 PM
