No power to starter 95 LS. Tired of pop starting.
Im haveing problems i took off my starter to test it because i thought it went out last night the starter ended up being good also ran my friends starter turns out there is no power going to the starter checked it with a meter . What can this be? What should i check for?
Re: No power to starter 95 LS. Tired of pop starting.
you sure you don't have power from battery to starter? It would be the battery cable that goes to the starter or it would be your igintion wire as well.
Try first Checking or replacing your .... PGM-FI Main Fuel relay...maybe Fuel pump giving out...bad injectors GL!
The power wire to the starter is a straight wire to the battery. No relay, fuse etc is involved. If you're not getting power, then the connections or the wire itself is bad. It couldn't be simpler than that.
EGed up from the seat up
05-13-2010 11:34 PM
OPTION2ek V.2
07-18-2005 10:05 PM
