No heat and cars overheating
Old 02-10-2010, 10:16 AM
acuralovar's Avatar
Default No heat and cars overheating
Ok last week my car was overheating because there was no fluid in the radiator( hose had a hole in it replaced it) ok now here and there my car gets in the 180 to 220 degree around and lately I'm always having to let air out of the system . Last night my radiator hose blew off and my heat was blowing cold air so I bought a new hose and replaced it and I added straight water .. Car was idleing for about 5 minutes and still no heat so I took it for a spin overheating new suddenly my heat is working and the car is not overheating. Now this morning I drive the car to work and no heat engine is overheating I've already Added water and it's holding it's not leaking. If it was the water pump would I hear it? And would it build up pressure?
Old 02-10-2010, 10:19 AM
lobudgetr's Avatar
Default Re: No heat and cars overheating
If it was water pump you would usually have a leak it would come out of the little hole in the water pump. I would suggest checking the oil to see if you have water and oil mixing might have blown head gasket.
Old 02-10-2010, 12:05 PM
SluggishDA's Avatar
hmmm i had no heater when my car was low on coolant you should check that out maybe
Old 02-10-2010, 12:10 PM
Mr. Carbon Fiber's Avatar
Change your thermostat. It is stuck on close position. Water pump have nothing to do with the heat core at all. No heat means you dont have coolant going into your heat core hence thermostat issue. Flush your system and make sure all hoses and clamps are tight. Check for defective radiator cap as well.
Old 02-10-2010, 12:37 PM
19fury69's Avatar
I would say put a new rad cap on it, sometimes they fail and it pressurizes the system and has your symptoms. If that doesn't fix it throw in a new thermostat and it should fix it.
Old 02-10-2010, 01:45 PM
racebum's Avatar
x2
Old 02-10-2010, 03:46 PM
Hackster's Avatar
This is the correct answer. Also be sure you bleed the system once you fill it to get any air out.
Old 02-10-2010, 03:55 PM
gsreg607's Avatar
yes.. this is my gess also^^^
Old 02-10-2010, 05:21 PM
masintegrafleet's Avatar
Put in a new thermostat for cheap and a new rad cap and a 50/50 mix of coolant and water and you should be warm and toasty.
Old 02-10-2010, 07:11 PM
dothacker's Avatar
first of all, putting straight water in your copper core radiator is just bad. drain that sucker and put 50/50 in it. i dont know how bad the snow is at your place but i wouldn't put water and 50/50. when you do that, bleed your system for air.
also, since you had your car overheat, hopefully the head gasket didn't get toasted. i'd ask someone to check though just in case.
Old 02-11-2010, 06:47 AM
jimjampants's Avatar
This is correct! Post back let us know how it works out.
Old 02-14-2010, 12:11 AM
acuralovar's Avatar
update" it was a leak that i couldnt even see at the bottom of my radiator . got new radiator and hose clamps now im nice and toasty , thanks for all the help guys
nonvtec92
14
11-28-2008 04:50 PM
warlockip
10-06-2008 09:02 AM
turbohb21
08-07-2007 08:43 PM
greasemonkee
11-24-2006 01:22 PM
93sidelsolvtec
10-08-2006 08:32 PM
Quick Reply: No heat and cars overheating
