No Break Pressue
Old Jun 5, 2011 | 02:54 PM
TonyRomo's Avatar
Default No Break Pressue
I took apart my caliper because I suspected it was seized.
Now I have no break pressure at all.
Do I need to bleed the entire system now?
Old Jun 5, 2011 | 03:19 PM
94VTEC2TONE's Avatar
Default Re: No Break Pressue
no you should have to bleed that side
Old Jun 5, 2011 | 06:42 PM
el crapitan's Avatar
you need to be more specific. what do you mean by you have no brake pressure?
you mean at the pedal? or at the caliper?
did the fluid level drop below the minimum mark on the reservoir while you had the caliper off?
Old Jun 5, 2011 | 06:43 PM
djkobe's Avatar
check the fluid level, then give the brakes a nice bleeding and it should bring the pressure right back
Old Jun 5, 2011 | 06:55 PM
TonyRomo's Avatar
No pressure at the pedal, disassembling the rear caliper seems to have affected all the other breaks.
The fluid didn't change at all.
Tomorrow I think I will try only the right rear and see if that helps.
If not I'm going to do all of them. I'm not looking forward to it tho, last time I tried bleeding a break I snapped the bleeder bolt right off and had to buy a new caliper.
Old Jun 5, 2011 | 07:21 PM
try bleeding the RR and LF. those 2 lines are connected. these cars run a X configuration of the lines
slacks
Apr 15, 2008 08:57 PM
rdssk8rcs1
Mar 31, 2008 04:09 AM
Kyles ej1
Jul 10, 2005 10:20 AM
rolledthatho
Mar 14, 2005 10:05 AM
