New pistons
Old 09-03-2006, 08:35 PM
WalkerGSR1's Avatar
Default New pistons
if i order new pistons, should i have the block honed? and get bigger pistons or stay with the stock 81mm bore. i have 75k on my car
Old 09-03-2006, 08:47 PM
WalkerGSR1's Avatar
bump
Old 09-03-2006, 09:34 PM
jdmintegralsvtec's Avatar
Default Re: (WalkerGSR1)
I think when you change pistons you need to change the piston rings and when you change the piston rings you do have to hone the cylinders. Not positive though.
Old 09-03-2006, 09:36 PM
Dartanian's Avatar
Default Re: New pistons (WalkerGSR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 &raquo;</TD></TR><TR><TD CLASS="quote">if i order new pistons, should i have the block honed? and get bigger pistons or stay with the stock 81mm bore. i have 75k on my car</TD></TR></TABLE>
Anytime the rings are changed, you need to have it honed. 81mm bore pistons are fine unless you have scratches that require an overbore. In that case, you would need oversized pistons.
Old 09-03-2006, 09:40 PM
-Championship-'s Avatar
Default Re: New pistons (Sleeper Style)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeper Style &raquo;</TD></TR><TR><TD CLASS="quote">
Anytime the rings are changed, you need to have it honed. 81mm bore pistons are fine unless you have scratches that require an overbore. In that case, you would need oversized pistons.</TD></TR></TABLE>
what would happen if you dont hone the block when installing new rings?
Old 09-03-2006, 09:42 PM
Dartanian's Avatar
Default Re: New pistons (CW_98gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_98gsr &raquo;</TD></TR><TR><TD CLASS="quote">what would happen if you dont hone the block when installing new rings?</TD></TR></TABLE>
They won't seal correctly and all the labor you just spent on replacing the rings was a waste.
Old 09-03-2006, 09:48 PM
They won't seal correctly and all the labor you just spent on replacing the rings was a waste.</TD></TR></TABLE>
hmm great...thanx for ruining my day lol, j/k but yeah, i bought new pistons and rings, and i took it to a mechanic and i dont think he honed the block, damn
Old 09-04-2006, 06:21 AM
scottishdave's Avatar
If you buy new pistons, then buy new rings..they go hand in hand...and if you replace your pistons and rings, then you gotta hone the block. Honing does not make the bore any larger, so you will be good sticking with 81mm. But honeing does make sure the new rings will seat and seal correctly. If your mechanic did not hone the block take it super easy on the car for the nest 500miles. Dont rev past about 4000rpm, and basicly drive like a grandma.
Old 09-04-2006, 06:48 AM
Nors's Avatar
Mechanic should have told you it needed a hone. Thats a bummer.
Old 09-04-2006, 07:36 AM
Mad Scientist
mmuller's Avatar
Default Re: (Nors)
If and only if the stock crosshatch is still visible and the cylinders are not egg shapped too much, you can just deglaze the walls with a ballhone and install new rings.
Good to go. Rings will seat just fine.
Modified by mmuller at 12:27 PM 9/4/2006
Old 09-04-2006, 07:43 AM
WalkerGSR1's Avatar
How much would it cost to install pistons and do a hone? can you give a ballpark figure?
Old 09-04-2006, 10:22 AM
DC5StylZ's Avatar
what if u go from ls pistons and rings to type r pistons and rings
Old 09-04-2006, 10:53 AM
atg1290's Avatar
Default Re: (hondacuraLs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacuraLs &raquo;</TD></TR><TR><TD CLASS="quote">what if u go from ls pistons and rings to type r pistons and rings </TD></TR></TABLE>
You should always replace rings when you are removing and isntalling pistons it allows for a better seal and same thign with the honing, it just cleans the walls so the rings can bond better therefore not leaking
oxSLEEPERxo
06-24-2007 12:11 PM
Mugencrxsir1
02-23-2006 06:55 PM
kublai
08-30-2005 06:12 AM
Mr. Vapor
08-28-2005 09:06 PM
Quick Reply: New pistons
