New to integras
Old Feb 25, 2010 | 03:27 PM
eg_21's Avatar
Default New to integras
ok long story short i went from ek to dc so i bought the 95 gsr and the front turn signals don't work, i opened them up to find out somebody cut the sockets and plugs, ok no biggie but i went and bought universal sockets, but the passenger side doesn't have any hanging cables to hook up my right side turn signal, where can i find the three wires to hhok up my socket so my signals work properly?
Thanks.
Old Feb 25, 2010 | 04:39 PM
eg_21's Avatar
Default Re: New to integras
anybody?
Old Feb 25, 2010 | 04:41 PM
Tarmac Junkie's Avatar
They probably cut the wires flush with the harness.
Old Feb 25, 2010 | 04:49 PM
Lord Helmet's Avatar
check the harness near the turn signal, more then likely they cut all the way to the harness area. easy fix if you know how to solder new wires into the harness. just go a junkyard that has hondas/acuras and take what you need. simple...done!!
Old Feb 25, 2010 | 04:54 PM
eg_21's Avatar
yeah i'm checking the harness tomorrow, the also cut the plug for the horn so those are the only 2 wires hanging there, i tried to find the three for the signal but i'll have to cut the black tape all over it to see if is there.
Old Mar 1, 2010 | 05:08 PM
eg_21's Avatar
ok they are wired up to right wires, now they turn on but front signals don't work rears do but fronts ones don't, i'm getting frustrated, could it be the universal socket? is a three wire one with ground and 2 more wires, i don't know what else to do, i'm going to get the original sockets and see if it works, any suggestions besides that?
Thanks
Old Mar 1, 2010 | 11:08 PM
Hektik Photography's Avatar
have you tried doing a voltage drop on the green wire?
Old Mar 2, 2010 | 11:05 AM
94VTECoupe's Avatar
woah woah woah. Watch the technical terminology, we're on Honda-Tech here hahaha jk jk. While we're at it, remember Kirchoff's second rule states that the total voltage in the loop is equal to the sum of the voltage drops in the loop haha
Old Mar 3, 2010 | 12:02 AM
umm was it the voltage drop before the load, at the load, and after the load should all then add up to the total voltage that goes into that system?
Old Mar 3, 2010 | 03:14 AM
unknownally's Avatar
WTF I'm lost. Quit it guys.
four wheel geek
Honda CR-V & Element
Jan 16, 2019 04:56 PM
ericnoss
Engine Management and Tuning
May 16, 2013 08:15 PM
FSS13foxtrot
Dec 28, 2007 01:01 AM
20ls01
Apr 22, 2007 12:18 AM
Zekers
12
Jan 30, 2005 02:46 PM
