new integra with problems
Old Oct 5, 2011 | 09:51 PM
lt1guy's Avatar
Default new integra with problems
so i got a 94 integra 4dr with a gsr swap now i pulled the head because lack of compression and got it rebuilt. know i got it running but it seems like its being held back.i just lost to a 06 scion xb when i get on it the check engine light comes on and it will throw codes 6,7,10,21 but i shut it off and the light wont come back on till i beat on it again.im thinkin ect sensor could be hurting performance if thats not good.both torque mounts are ripped so im thinkin during hard shifts or vtec engagement the motors movin alot and maybe pulling some plugs a way a little bit. if anyones heard or seen any kind of problem like this input would be much appreciated.oh and the gauge cluster lights dim at idle on and off but those only(dont think its the alt) is that a common prob on these things first teggy.
Old Oct 6, 2011 | 07:00 AM
kimsuprapa's Avatar
Default Re: new integra with problems
Codes 6,7,10,21
Did you look up and fix the codes?
Old Oct 6, 2011 | 07:48 AM
lt1guy's Avatar
I know Wat the codes are but I have vtec it only happens at wot it will come on an
d be off when I start the car again I know a 4 Dr gsr isn't gona be the fastest but def faster than a stock xb I'm gona time it with a timing light today maybe ignition timings off but anybody ever have codes pop up during wot around 5500 rpms or could it have something to do with not having the gsr manifold on it
Old Oct 6, 2011 | 07:54 AM
HondaPartsHero's Avatar
Technical Hero
6 ECT Sensor (Engine Coolant Temperature)
defective circuit or unplugged / defective sensor
7 TP Sensor (Throttle Position)
10 IAT Sensor (Intake Air Temperature)
21* VTEC Solenoid Valve
defective circuit or unplugged / defective solenoid valve
* not a valid code if car does not have a VTEC engine
** not with V-6 engine
Check to make sure you don't have the MAP and TPS backwards.
Old Oct 6, 2011 | 12:51 PM
lt1guy's Avatar
I would think if the map and tps were mixed up they would both throw codes at all times
Old Oct 6, 2011 | 01:18 PM
Dioxine's Avatar
And the car would run like complete poo. I would start off by checking the wiring harness. Its a little weird that it only happens at wot and around 5500. Does your vtec kick in at 4800 or 5500, do you know what ecu you are running.
Old Oct 6, 2011 | 04:06 PM
lt1guy's Avatar
Its a p72 and it kicks in at 4800 I timed it with the light and it runs a lot better but the light still comes on and I'm pretty sure my alternator is goin out to with the flickering lights at idle could that have somthin to do with it cutting out at that rpm maybe and trippin the light
zrs6v4
Dec 3, 2020 02:23 PM
HONDRETTI
May 8, 2008 12:52 PM
ekhatch978
Aug 1, 2007 05:44 PM
94b16teg
Aug 4, 2006 09:39 PM
onereving7
Jul 11, 2004 09:27 PM
