need to wire up a vtec controller???
Old May 1, 2006 | 06:26 AM
DA-9mordef's Avatar
Default need to wire up a vtec controller???
i have a vafc dont know how to connect any suggestions??
Old May 3, 2006 | 08:10 PM
RonaldHam's Avatar
Default Re: need to wire up a vtec controller??? (DA-9mordef)
you just have to read the manual and it tells you which wires to install things to and how to do it if its wrong you will throw a constant check engine light so install the VTM wire and the Pressure wire in the correct spots and then see what happenswill take an hour if you take your time and solder all junctions and make sure any crimps are perfect and then make sure it will start if not then start over BUT REMEMBER DO NOT <U></U> CUT any of the wires unless it tells you to because that will foul the system and make things difficult for you
00supercivic
Nov 13, 2004 09:47 PM
aces1980
Aug 1, 2004 10:05 AM
Black Sheep
Feb 19, 2003 09:11 AM
Type RS
Feb 5, 2003 02:27 AM
