HELP!
Old May 27, 2005 | 09:30 AM
HDNBenjamin's Avatar
Default HELP! gear problem
the bike was laid down at 0 mph when it was parked on a slanted ground. Now it's hard to shift gears. I sometimes can get into 1, neutral, 2nd and third. BUt it wont go up anymore gears. It doesn't click or go smoothly as before. Any suggestions? it seems to be jammed.
Old May 27, 2005 | 09:35 AM
EGlovr's Avatar
would it have something to do with the tipover sensor?
Old May 27, 2005 | 09:46 AM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Default Re: HELP! gear problem (HDNBenjamin)
did it land on your shifter side? maybe the shifter rod is slightly bent.
Old May 27, 2005 | 09:52 AM
The Specialist's Avatar
Default Re: HELP! gear problem (ScareyH22A)
Check the shifter shaft same thing happen to my friend.
Old May 27, 2005 | 10:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">did it land on your shifter side? maybe the shifter rod is slightly bent.</TD></TR></TABLE>
yup on the shifter side..sigh..im really depressed. gf and i just broke up and now this ****. i have to stay in 2nd or third most of the time for the fear of not being able to go back to it if i do shift.
Hatchman98
Mar 20, 2007 10:51 AM
ProjectCD5
Feb 21, 2006 11:55 PM
Kyles ej1
14
Oct 2, 2005 09:27 PM
batzcivic
Jun 9, 2005 04:21 PM
BAZ
Jul 29, 2003 09:29 PM
