need help vtec press. valve code
Old Sep 9, 2004 | 03:24 PM
JDM_Risa's Avatar
Default need help vtec press. valve code
i checked my friends 94 gsr today.....
it threw this code
-22 VTEC pressure valve
how do you go upon fixing this......
when he goes fast he says the check engine light goes on
need replies asap..
thanks
Old Sep 10, 2004 | 02:26 AM
JDM_Risa's Avatar
Default Re: need help vtec press. valve code (GunMETAL_TEgRa)
ttt
Old Sep 10, 2004 | 02:49 AM
SicNA94TegGsR's Avatar
Swollen Member
Ill look it up when I get to work
Old Sep 10, 2004 | 04:09 AM
JDM_Risa's Avatar
Default Re: need help vtec press. valve code (SicNA94TegGsR)
thanks
Old Sep 10, 2004 | 04:47 AM
JimBlake's Avatar
22 = VTEC oil pressure switch. The ECU won't engage VTEC unless it's happy with the oil pressure.
On my '95 GSR it's screwed into the VTEC spool valve, so it's sorta below where the plug wires curve around from the distributor. It looks kinda like the fan switch & the ECT sensor. I think it has a green plug??
Could be his oil is low? Maybe the wiring is loose or corroded on that sensor? Maybe the wiring is broken somewhere between the sensor & the ECU?
Old Sep 10, 2004 | 04:59 AM
Swollen Member
well asking about.....and 90% of vtec codes come from oil related probs, weather its dirty, sludged up, or low. also check the screen inbetween the valve and the head, that may be cloged. if that doesnt fix it, I will give you the specs of the switch, so you can test that
Old Sep 10, 2004 | 02:20 PM
JDM_Risa's Avatar
thanks for the help.....its fresh new oil 4 qts are there along with a rsx oil filter
Old Sep 10, 2004 | 04:32 PM
Swollen Member
well, its prob the switch then, Ill get specs when I get to work tomorrow then
Old Sep 10, 2004 | 04:33 PM
Swollen Member
ok...and I assume that the RSX filter is the same as all the other honda filters, and that they didnt change it
Old Sep 14, 2004 | 07:48 AM
Swollen Member
first off check continuity of theswitch, if there is none, replace it.
then off the connector, check contiuity beteween the black term and body ground
its most likely the switch, if that doesnt do it, ill type more, but there is alot of stuff to be checked
Cameron707
Jul 18, 2015 05:20 AM
hott-nix
Aug 26, 2004 11:46 AM
BobGnarly
May 23, 2004 05:28 PM
incubus
Feb 3, 2003 08:56 AM
shonnys92si
Jan 20, 2003 11:45 PM
