need help tuning vtec controller
Old Mar 3, 2007 | 06:11 PM
blkvtec96's Avatar
Default need help tuning vtec controller
started playing with the controller and am trying to have the vtec kick in earlier but its running like **** any one know about these controllers i got a 96 gsr
Old Mar 3, 2007 | 06:21 PM
ALLMOTOR CRX's Avatar
i would like to know as well before i connect my **** in my crx.. thats the reason why i dont want to connect mine im afraid of running it like crap
Old Mar 3, 2007 | 06:24 PM
Padawan's Avatar
Darth ModerVader
Default Re: need help tuning vtec controller (blkvtec96)
If you aren't tuning these on a dyno, you're simply making blind adjustments with no way of knowing what effects your adjustments are having. These are intended to be legitimate tuning tools, not something to play around with.
Old Mar 3, 2007 | 06:40 PM
blkvtec96's Avatar
so should i get i t tuned or does anyone have specs were it should b
Old Mar 3, 2007 | 06:41 PM
jorge59la's Avatar
Default Re: (blkvtec96)
tuning is better!
Old Mar 3, 2007 | 06:59 PM
what if you bought one that was already install on a gsr before your just swapping out from cars would it still work the same?
Old Mar 3, 2007 | 07:02 PM
Padawan's Avatar
Darth ModerVader
Default Re: (ALLMOTOR CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTOR CRX &raquo;</TD></TR><TR><TD CLASS="quote">what if you bought one that was already install on a gsr before your just swapping out from cars would it still work the same?</TD></TR></TABLE>
Not really, because each engine is slightly unique, and therefore each requires its own settings.
Old Mar 3, 2007 | 07:03 PM
Damon Reeves's Avatar
Honestly, I have to say that the Vafc controller cannot be tuned blindly...you have to get your car onto the dyno....before that just get the basics...header, intake manifold, perhaps chipped ecu, cams, and then get to your local shop to get her tuned.
Old Mar 3, 2007 | 07:20 PM
yep thats exactly what im planning to do on mine install basics and get her tune.. i had a question i have a p28 chipped with crome and when i install it in my gsr motor the thing dies out on me its like it needs some gas or something. the dude i bought it from told me it was tune on some 440cc injectors i have stock. could that be the problem why my car dies out as soon as i turn it on? i mean with my p72 ecu it works great...
Old Mar 3, 2007 | 08:34 PM
aaronhume's Avatar
Default Re: need help tuning vtec controller (hondatechfan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatechfan &raquo;</TD></TR><TR><TD CLASS="quote">Honestly, I have to say that the Vafc controller cannot be tuned blindly...you have to get your car onto the dyno....before that just get the basics...header, intake manifold, perhaps chipped ecu, cams, and then get to your local shop to get her tuned. </TD></TR></TABLE>
or you could runa wideband O2 kit (innovative LC-1) and plug that into a laptop and get the tuning pretty close, but not perfect without data logging. I had that in my old car, but its a two person job to tune it. and vtec on the low end usually doesn't' help much
and for the injector question, yes it would effect how your fuel delivery is. when you program a chip and tell it you have 440 injectors instead of 240, it will only pulse for about half the time, so realistically you are only getting half the fuel you need, so either get a new chip burned or find some DSM 440 injectors to run with it so it will actually drive.
4sup513
Jul 8, 2005 06:44 PM
Bictorious
Jan 18, 2004 11:13 AM
kool168
Oct 15, 2003 05:27 PM
AK94GSR
Jun 4, 2003 07:25 PM
liquids0ap
Apr 26, 2003 07:21 PM
