need help with a reving problem
ive got a 01 gsr rebuilt over a year ago and i let it sit, i have a problem with it flooding every time i rev it will choke down and die but will idle fine. i have changed the tps the map senser and the idle air control valve. the code that shows is a (p1298 manufacturer controled fuel air mixture) if any one knows anything please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bstaton »</TD></TR><TR><TD CLASS="quote">it was perfect and it seams to be still workin</TD></TR></TABLE>
I would test the distributor. There is an article somewhere on T-I.net
yeah i had the same issue when i did a swap on my friends car,, i checked everything and turned out to be a loose cable on the dizzy
,,, all after i changed ecu,checked all wiring except the dizzy,, good luck mang
those are hard to diagnose,, cause it could be anything,,,,from an injector to valves,valves springs ect.
i took the plugs out and it is flooding bad. and the new codes are (p1399 ignition system or misfire) and (p0141 o2 sensor missing) and (p1298 manuifactur controled fuel/ air metering) and a high input map
GRPNHRD
16
Nov 29, 2005 09:44 PM
