Idle Surging... Already searched...
Allright heres the problem... I have a 94' Civic with a ITR swap... Last week right before my fuel pump gave out my car started having this problem. It began idling at about 1100rpm's when I first would start it up... But slowly after it warms up it starts flucuating between 600-900rpms. Yesterday I installed my new fuel pump and checked the pressure (which is where it supposed to be), but im still having this low/flucuating idle. I already searched and saw many posts about erratic idlling, but nothing like mine that came out of the blue. I am trying to see if anyone has any info on what I can check or do to fix this problem? Thanks in advance for any info!
Re: Idle Surging... Already searched... (Hella_JDM)
check for vacuum leaks... sounds like that's probably the problem. If you cannot find a vacuum leak... then try cleaning your IAC (Intake Air Control Valve) and see if that does you any good.
Re: Idle Surging... Already searched... (EG6GRPNHRD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3dh4tch »</TD></TR><TR><TD CLASS="quote">check for vacuum leaks... sounds like that's probably the problem. If you cannot find a vacuum leak... then try cleaning your IAC (Intake Air Control Valve) and see if that does you any good. </TD></TR></TABLE>
i am not sure if those engines have a FITV but if it does and the FITV isnt working properly (say its closing but not sealing right) then it will have a slight vacuum leak and your idle will fluctuate.
mine does this, idle at 1500 when cold, which is normal, but when the temp comes up to normal and the FITV closes, it isnt closing all the way and makes me idle from 600 - 900 and its random when it does it.
if you have an FITV you can check this by taking off the intake tube and the LOWER hole in the TB put your finger over it, if you feel suction when the engine is up to normal temp then its not closing all the way.
Re: Idle Surging... Already searched... (93egsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsedan »</TD></TR><TR><TD CLASS="quote">
Yea I know that trick... But theres no FITV in my car, Thanks for the help though!
Re: Idle Surging... Already searched... (r3dh4tch)
first of all IAC is idle air control, and that could be most likely your problem you need to get the specs and check with a volt meter should fluctuate while reving. its a stepper sencor so just climb rapidly but in spurts, and the sam when falling, they can be cleaned but usually start again a week later.
Re: Idle Surging... Already searched... (postman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman »</TD></TR><TR><TD CLASS="quote">first of all IAC is idle air control, and that could be most likely your problem you need to get the specs and check with a volt meter should fluctuate while reving. its a stepper sencor so just climb rapidly but in spurts, and the sam when falling, they can be cleaned but usually start again a week later. </TD></TR></TABLE>
Yea, I tried cleaning it as best as I could... Still having the problem, should I just go pick up a new IAC? Would the IAC just go out randomly without throwing any CEL's?
* B A N N E D *
could be a mad bubble in the coolant.
try running the engine, let it get warm, then open the bleeder on the thermostat housing.
probably not, but could be.
Re: (EGmikeH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGmikeH22 »</TD></TR><TR><TD CLASS="quote">could be a mad bubble in the coolant.
probably not, but could be.</TD></TR></TABLE>
I'll try tomorrow, to dark to see anything right now. Thanks for the help guys!
Re: (RedZone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone »</TD></TR><TR><TD CLASS="quote">sent you a PM and email</TD></TR></TABLE>
Thanks Jeremy!
Thanks Jeremy!
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6GRPNHRD »</TD></TR><TR><TD CLASS="quote">Idle Surging... Already searched...</TD></TR></TABLE>
You're full of ****:
» Search Results
Your search for <FONT COLOR="blue">idle surge</FONT> returned 73 results.
» Search Results
Re: Idle Surging... Already searched... (Archidictus)
intake manifold gasket.. 14 bucks..
i tried everything.. and that was finally the answer..
spray some carb cleaner all over and see if there is a leak ..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
» Search Results
Your search for <FONT COLOR="blue">idle surge</FONT> returned 73 results.</TD></TR></TABLE>
I did search and didnt come up with anything that helped me... So
» Search Results
MKEK9
11
03-06-2007 04:55 PM
