Need help placing fuse box in my EG6 with wire tuck.
I need help trying to figure out what I can do with the fuse box from underneath the hood. I did a wire tuck and this is the only thing I have left to do, someone told me to cut a hold in my AC box and put it in there except I don't have the tools to cut into that. Another guy told me to take out the glove box and put it in the dash I tried that but there isn't a spot to put it.
I am building a 1993 Hatchback cx with a B16a and GSR tranny behind it, this is the only thing I have left on the wire tuck before I throw the motor in.
Re: Need help placing fuse box in my EG6 with wire tuck. (iamthefollower)
how can you not have room behind the dash in a cx???? there is tons of room....
Re: Need help placing fuse box in my EG6 with wire tuck. (J. Funk)
Maybe you should ask the forum with civics not integras
Well you know what, that was my bad. Didn't know that this was the integra forum considering that I am new with this, so their wasn't any since in being a ***** if you didn't have an answer besides that you shouldn't have posted anything.
Re: Need help placing fuse box in my EG6 with wire tuck. (lance_dc2)
Their isn't a lot of room behind the dash of a CX, if you take out the glove box their is a plastic piece up above it and then their is the heater box and everything else behind it.
if you are running a lil race car, u can pull the ac/fan box behind your glove box out. youll have no air in your car, but the fuse box will fit in there. unplug from outside, then redirect the cables back into the firewall
Re: Need help placing fuse box in my EG6 with wire tuck. (95egferio)
Ok, i've took all the other AC stuff out except that. I appreciate the info man.. Thanks.
Josh DeMoss
10
03-17-2016 03:24 PM
andyhoiho
05-29-2004 07:58 AM
TouringAccord
03-08-2004 03:05 AM
