need help i have a cel code 67
Old Jul 4, 2002 | 04:53 PM
LillDragun's Avatar
Default need help i have a cel code 67
i need to know what this is. and what to do. i ran a search but i didn't understand what they were sayin on the post. thanx
Old Jul 4, 2002 | 04:54 PM
StinkyTofu's Avatar
Default Re: need help i have a cel code 67 (LillDragun)
Its a Bullshit code. Just ignore it. Its the secondary o2 sensor on the cat i believe. If you just changed to high flow cat, that could be the reason. If you're still all stock then i don't know what could be wrong. reset your ecu and see what happens.
Old Jul 4, 2002 | 05:06 PM
Goy091's Avatar
Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
http://www.c-speedracing.com/faq/05.html
Old Jul 4, 2002 | 08:59 PM
LillDragun's Avatar
Default Re: need help i have a cel code 67 (Goy091)
if i replace the O2 sensor that could fix it right?
Old Jul 4, 2002 | 09:45 PM
lsteggy's Avatar
nope
Old Jul 4, 2002 | 09:49 PM
LillDragun's Avatar
Default Re: need help i have a cel code 67 (lsteggy)
nope
well my car is only a year old. i have about 20k miles on it
Old Jul 4, 2002 | 10:05 PM
StinkyTofu's Avatar
My car has 8k and i've gotten that code like 20 times. Welcome to the "Code 67 club".
Old Jul 6, 2002 | 06:10 PM
LillDragun's Avatar
Default Re: need help i have a cel code 67 (StinkyTofu)
so what should i do to fix the problem? i don't wanna get a new cat. could it be because i have a 2.5 in. cat back exhaust?
Old Jul 6, 2002 | 06:31 PM
StinkyTofu's Avatar
Yeup you answered your own question. The stock OBD2 ecu is very sensitive to any changes in airflow. I don't know if it is your cat or not. I'm thinking it is just the ecu. In that case the only way to fix it is to get an obd 1 ecu. I have also heard of people taking the o2 sensor out, welding the hole in the cat, and wrapping the o2 sensor in foil or something.
Old Jul 6, 2002 | 08:04 PM
neo1z's Avatar
i have that code as we speak...of course im running a tp tho
nutball72
Aug 10, 2007 03:05 PM
Ra GS-R
Jul 4, 2007 06:35 PM
Frostwhite_DB8
Jun 2, 2007 09:33 AM
LillDragun
Jul 11, 2002 05:47 PM
lopey
Mar 10, 2002 12:28 AM
