need help finding correct cd player......
Old Mar 28, 2006 | 01:32 PM
lev16gt's Avatar
Default need help finding correct cd player......
Ok, so I'm in desperate need of a cd player for my 1994 Integra LS (my sony is old and screwing up). I am looking for a stock Integra cd player. I thought I could use any '94-01 cd player but after searching around I am getting mixed results. Some say any year will plug right in and mount/bolt right up and others say that you have to cut and rewire the harness and or drill new holes to mount it for certain years. Anybody know for sure what years of acura or honda cd players I can use for my '94 Integra LS that will plug right in the harness and bolt up correctly?
Cliffs: What year/model oem cd players can I plug right in and bolt right up to my '94 Integra LS?
*any help would be greatly appreciated...and as stated above, I already searched*
Old Mar 28, 2006 | 01:42 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: need help finding correct cd player...... (lev16gt)
I dont see how any wouldnt fit considering they are all single din head units, unless the tray part is smaller in the older tegs than the newer ones..
Old Mar 28, 2006 | 01:43 PM
Tornadom's Avatar
I could be wrong, but I am not sure 94 Integras were available with an in-dash CD player. I thought that the 94 model Integras had a cassette deck, and an optional trunk mounted CD changer. With that said, I think any CD palyer from an Integra will work.
Old Mar 28, 2006 | 01:44 PM
.brian.'s Avatar
Default Re: need help finding correct cd player...... (Tornadom)
make sure you get the code for the cd player if you do get factory, as it will not work with out it.
Old Mar 28, 2006 | 01:52 PM
Guess whos bizzack
Default Re: need help finding correct cd player...... (.brian.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .brian. &raquo;</TD></TR><TR><TD CLASS="quote">make sure you get the code for the cd player if you do get factory, as it will not work with out it.</TD></TR></TABLE>
actually you may know this but theres not really a point of having the code..All you have to do is call your local Acura parts department and read them the serial # from the back and they give you a code no questions asked
Old Mar 28, 2006 | 01:57 PM
purplegsr's Avatar
Default Re: need help finding correct cd player...... (BOLO-FTW!!)
The wiring harnesses changed between 1996 and 1997, so you will want to find a cd player from a 1994-1996 Integra, if you don't want to change harnesses. Of course, if you are comfortable with cutting the wires and using electrical tape or fasteners to splice wires together, you can follow the diagrams in this link (or you could get an adapter to convert it to the newer style as well).
http://www.installdr.com/Harnesses/HA-Wiring.pdf
Old Mar 28, 2006 | 02:02 PM
RexShop's Avatar
I just took my CD player out of my 98 gsr.. I dont have the security code for it.. but I'll sell you the CD Player.. PM me.
rstepan
Oct 29, 2009 11:54 AM
Coreatown
Audio / Security / Video
Aug 10, 2008 04:23 PM
Mitcher
Jun 8, 2007 09:26 AM
thatasiankidtony
14
Sep 4, 2006 11:35 AM
lev16gt
Mar 28, 2006 07:19 PM
