Need Help With Fields Vtec Controller??!!
Old Jun 16, 2003 | 12:00 PM
AK94GSR's Avatar
Default Need Help With Fields Vtec Controller??!!
I bought a fields controller off of a friend the other day. I used the helms and made sure i have it hooked up correctly. The controller is reading vtec and rpm just fine, no problems there, but when i step on the gas real quick my car feels like it is boggin out and wants to stall or it wont let me pass 2krpm??
but when i lean in to the throttle slow is works just fine.
nto sure whats going on, but i was wonderin if it had anything to do with that VTN line. They say something about taping one end of this up??
what do they mean by that?
Old Jun 16, 2003 | 02:21 PM
AK94GSR's Avatar
Default Re: Need Help With Fields Vtec Controller??!! (AK94GSR)
does anyone know who i could contact about this??????????/
Old Jun 16, 2003 | 03:51 PM
Tweakmeister's Avatar
yeah I'd read the V-AFC install directions (free download off their site)...they have a few bugs fixes in terms of proper wiring that would probably work.
Old Jun 16, 2003 | 04:30 PM
AK94GSR's Avatar
Default Re: Need Help With Fields Vtec Controller??!! (Tweakmeister)
i've looked at most of these but ill check over everything once more, im pretty sure everything has a good connection though
anyone else have any suggestions
Old Jun 16, 2003 | 04:39 PM
Ivan's Avatar
senior gold member
have you tried setting your setting back to zero?
Old Jun 17, 2003 | 07:02 AM
Xsi's Avatar
Xsi
Try turning the unit off and see if it makes a difference
Old Jun 17, 2003 | 11:35 AM
AK94GSR's Avatar
Default Re: (Xsi)
I turned everything back to "0" when i first got it hooked up, and put the stock vtec point in since its defaulted to 4500.
And yes i have tried turnin it off. Its off right now since its not workin right
anyone know who i could contact?
Old Jun 17, 2003 | 02:46 PM
AK94GSR's Avatar
Default Re: (AK94GSR)
k then
who the hell makes these things
Old Jun 17, 2003 | 03:28 PM
Xsi's Avatar
Xsi
Check the plug into the back of the unit, they're often loose.
I ended up cutting the plug off and soldering it straight into the unit.
Old Jun 17, 2003 | 04:28 PM
AK94GSR's Avatar
Default Re: (Xsi)
Mmmmm, weird
im pretty sure its ok, since it never left my buddies car after being installed professionally, i was there helping him take it out too, we were very careful with everything.
ill double check though
oh and jsut to make sure im supposed to tape off the VTM wire and just connect the fileds straight to the ecu right
Old Jun 18, 2003 | 06:01 AM
Xsi's Avatar
Xsi
Yep, that sounds right. If everything is the same as in the manual then there must be something wrong with the SFC. Double check your wiring anyway.
Old Jun 18, 2003 | 07:23 AM
acatak's Avatar
Default Re: (Xsi)
thoses things suck... i used to have one, and I am now looking to get a vafc.... sell it, i know plenty of people that have had those go bad on them
em1gangsta
36
Mar 30, 2008 11:02 PM
hybridmiklo
Feb 20, 2005 08:51 AM
Los.
Dec 24, 2004 11:25 PM
jay-tec
Nov 17, 2004 04:12 AM
Rob :190:
Apr 6, 2002 03:25 PM
