Need Help, Clutch Replacement Problems
Old Aug 28, 2007 | 02:11 PM
1g's Avatar
1g
Default Need Help, Clutch Replacement Problems
everything went together fine, got the car finished went to take it for a test drive. shifts perfectly on with the motor off, refuses to go into gear with it on, so of course i think the clutch isnt disegaging, so i bleed the clutch, find out the master cylinder is leaking, replace that, bleed them 5 or 6 times. still doesnt help. then i swap the slave cylinder. STILL NO SHIFTS!
only thing i can think of is, as i tightened the pressure plate, the fingers on it sunk towards the flywheel about 1/2 to 3/4 of an inch. there no play in the clutch release fork with my foot off the clutch and it travels about 1 1/2 inches in the stroke.
im really frustrated since im doing this as a favour to some girl, im about ready to **** myself im so mad.
Old Aug 28, 2007 | 04:34 PM
1g's Avatar
1g
Default Re: Need Help, Clutch Replacement Problems (1g)
ttt
Old Aug 28, 2007 | 04:41 PM
IN VTEC's Avatar
You may need to adjust the clutch pedal down a little. I ran into that problem with a '03 Accord once.
Mikeyb918
Oct 31, 2012 05:55 PM
favd21
Transmission & Drivetrain
Sep 8, 2012 03:00 PM
B18c5__Owns
Aug 8, 2008 04:24 PM
92BlackSi
Oct 26, 2004 03:51 PM
blkgsr03
14
Sep 16, 2004 05:19 AM
