NEED HELP ASAP: Stalling while Coasting
Old Aug 4, 2011 | 07:33 PM
bvillarreal's Avatar
Default NEED HELP ASAP: Stalling while Coasting
Ok so about 3 days ago all of the sudden I was coasting in 4th and went to downshift to 2nd, all of the sudden the car died. Now its every single time i press the clutch in while under more than idle RPMs the car just stalls. Any suggestions? Cleaned IACV and raised the idle a little but still nothing.
Old Aug 5, 2011 | 04:22 AM
Default Re: NEED HELP ASAP
ttt its a b16 btw
Old Aug 5, 2011 | 04:47 AM
92lx's Avatar
good luck getting a responce for any help on this site.but my civic did that and it was my intake manifold gasket went bad.
Old Aug 5, 2011 | 06:10 AM
fcm's Avatar
fcm
Old Fart
Have you checked for vacuum leaks?
Have you checked to see what you are loosing, fuel or spark?
What is the fuel pressure when engine stalls?
Have you checked wiring in the engine bay, all engine sensors, valve/solenoids plugged in?94
Old Aug 5, 2011 | 07:28 AM
also did compression check and got 180,175,150,170 and getting some crankcase pressure...
Old Aug 5, 2011 | 07:04 PM
fcm's Avatar
fcm
Old Fart
150 is a little low compared to the others, [more then 10% off] but should not prevent engine from starting.
How about the other things I mentioned?94
Old Aug 8, 2011 | 12:02 PM
everything else is goood :/ could it be pressure plate? ive herd that bad plates can do this?
Old Aug 9, 2011 | 08:55 PM
ttt
Old Aug 9, 2011 | 09:01 PM
wunfstgsr's Avatar
Loved
Community Favorite
sounds clutch related, either the clutch pedal is off or the sensor on the clutch pedal is damaged or the clutch its self is not engaging right and causing the motor to shut of almost like when you take off in first but dont give enough gas the motor will stall and shut off.
Old Aug 9, 2011 | 09:51 PM
RecklessEJ's Avatar
4th to second yea no thats reasonable makes sense weird how it caused a problem for ya
Old Aug 9, 2011 | 11:04 PM
eclipsedsundown's Avatar
b16 have your integra trans or the b16 trans on it? Obd1-Obd2?
Old Aug 10, 2011 | 06:36 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: NEED HELP ASAP: Stalling while Coasting
Have you set the base idle on the car?
Old Aug 10, 2011 | 07:01 AM
its a b16 tranny, obd0 but i have obd1 conversion for the ecu and dizzy... idle was set when it got tuned, but i cranked the idle up a little more myself to try to keep it from stalling.. didnt work. It only shuts off say if im going 50 in 4th and i let off the gas and press the clutch in, car stalls. at an idle the car will not stall when i press the clutch in, however the idle will drop drastically.
Old Aug 10, 2011 | 04:59 PM
fcm's Avatar
fcm
Old Fart
Have you checked the TPS yet? 94
Old Aug 10, 2011 | 09:31 PM
Yeah if your TPS sensor has just the slightest offset it will think the throttle is closed all the way and cut fuel for the injectors. You can slightly unscrew your TPS just enough to move it with a little effort from the fingers and you can fell when the spring inside moves with contact to the throttle body. I mean it's just about 1mm of movement or less.
Old Aug 11, 2011 | 08:26 AM
do that with car running???
Old Aug 11, 2011 | 07:49 PM
wunfstgsr's Avatar
Loved
Community Favorite
no motor should be off but the power should be on then you test the wires on the tps with a probe to see if its within range i think 4.5 ohmz at wot.
Old Aug 12, 2011 | 03:58 AM
Dogginator's Avatar
Daisy... Daisy...
The TPS outputs volts, not ohms. It should smoothly transition in the 0.5 to 5 V range.
Old Aug 12, 2011 | 11:51 AM
redDAinteg's Avatar
Map sensor
Old Aug 16, 2011 | 10:28 PM
Yes.
codylesak
Oct 14, 2010 06:32 PM
nicklp60452
Jul 14, 2008 02:53 AM
B18CivicDriver
Apr 20, 2006 05:48 PM
hb_racer
23
Nov 23, 2001 09:44 AM
