need help
Old Dec 8, 2004 | 09:27 PM
jgocela's Avatar
Default need help
My 94 ls teg is making clicking noises on the front wheels. This happens when moving forward or backward. Didn't want to aggrevate the problem so my teg has been sitting in the driveway for weeks now. No one around can seem to give me a straight answer. Don't really want to spend a lot of $$$ if I don't have too. I normally do my own repairs. Hoping someone in H/T can help.
Old Dec 8, 2004 | 10:07 PM
sabotage7's Avatar
Default Re: need help (jgocela)
could be a cv joint.....is the noise coming from both front wheels though?
Old Dec 8, 2004 | 11:20 PM
Calsonic's Avatar
Default Re: need help (sabotage7)
Check your CV boot if it's torn or ripped. If it is, then looks like dirt probably got in there and that can cause problems. Usually a bad CV joint will make a clicking noise while turning.
Old Dec 8, 2004 | 11:24 PM
shorto85's Avatar
Sounds like you need new axles
Old Dec 9, 2004 | 10:38 PM
jgocela's Avatar
cv joint problems --- not likely because the noise happens when the wheels roll regardless if i'm turning or not.
need new axle? no one's ever told me that but i'll look into it.
thanx for the input guys
any other suggestions are welcomed, just need help
TunerShark
25
Nov 4, 2006 03:30 PM
ek9800
Dec 27, 2004 09:52 PM
tonezilla
Jan 15, 2004 02:01 PM
killerboots
May 1, 2003 06:29 PM
