my trunk won't open!
Old 07-31-2011, 01:51 PM
mr_loy's Avatar
Default my trunk won't open!
so my trunk is stuck and wont open.. the only way to open it is to use the key.. now when i try to use my key it wont open.. i've opened my panels in the trunk and cant see what the problem is.. has anyone had this problem?
Old 07-31-2011, 05:21 PM
creed86's Avatar
Default Re: my trunk won't open!
sounds like the actuator is broken. It's a common problem with integras. There's a write up on TI. Give that a shot.
http://www.team-integra.net/forum/bl...-actuator.html
Old 07-31-2011, 06:02 PM
fcm
Old Fart
fcm's Avatar
I'm guessing lock linkage, #32 broke, [plastic] and #12, [metal] is hanging off #10, [metal]...
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Cable, [#17] must also be disconnected or broken, it is also possible the lock itself, [#9] is broken.
You will have to use something, [screwdriver] to move the lever #12 is/was attached to, if that does not work you will have to unbolt the latch.
MM&Y of car would help, parts diagram is for a 94 Integra 4 door.94
ramboPandA
11-25-2013 09:23 AM
116souljah
Honda Civic (2001 - 2005)
06-01-2011 02:55 PM
Moto DC2
07-19-2007 05:51 AM
GuCCi_GSR
09-10-2005 12:43 AM
hYpE-R-29
04-19-2003 08:59 AM
Quick Reply: my trunk won't open!
