MSD Ignition Question
Old Apr 19, 2004 | 04:23 PM
  #26
turbo craig's Avatar
Default Re: (cougar10ag)
i had the same prob as u so i moved the battery to the trunk...4 guage wire will work fine
Old Apr 24, 2004 | 12:09 AM
  #27
integra-modder's Avatar
Default Re: (turbo craig)
Do you have any more info about the battery relocation? Pics of how you mounted it or anything?
Old Apr 24, 2004 | 10:23 AM
  #28
Default Re: (integra-modder)
heres an old *** pic but u gt the idea...no spray anymore
Old Apr 24, 2004 | 11:06 AM
  #29
Boofster's Avatar
Take apart the bottom. Make holes in the plate and put two brackets on the box with screws and bolts. Screw the box back to the plate on all four corners. I displaced the ABS control black box to another bolt to the side and put the MSD where that box was. Cut about one inch of hose and slice it. Wrap that around the abs hard line so it acts as a vibration dampener. The box makes a small buzzing noise so you don't want it inside your car.
Old May 1, 2004 | 08:47 AM
  #30
Default Re: (Boofster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boofster &raquo;</TD></TR><TR><TD CLASS="quote">Take apart the bottom. Make holes in the plate and put two brackets on the box with screws and bolts. Screw the box back to the plate on all four corners. I displaced the ABS control black box to another bolt to the side and put the MSD where that box was. Cut about one inch of hose and slice it. Wrap that around the abs hard line so it acts as a vibration dampener. The box makes a small buzzing noise so you don't want it inside your car.
Do you have any more up close pics? I think I want to try to mount mine like this.
Old May 1, 2004 | 12:59 PM
  #31
ernald711's Avatar
Default Re: MSD Ignition Question (white_98_gsr)
mine is mounted at the firewall, too. and the external coil is on a fabricated metal piece that sits on the upper chasis under the CAI on the left, so the wire routes under the CAI. also i do hear like a little hum. ignition plus my CAI together make different harmonies at different RPMs i love it. MSD help my car up the gas mileage. and because i drive on the freeways a lot i barely have to tap the gas at 5th to keep my car moving, even on the uphills where most tegs have problems.
Old May 1, 2004 | 08:42 PM
  #32
IN VTEC's Avatar
I test-fitted a SCI box tonight on my OBD-1 GS-R. It'll clear the ABS pump. It's perfectly snug behind the pump.
I'm gonna have to split the loom and reroute the ABS relay box wiring and that's pretty much it except for fabricating a mounting plate and bracket for the MSD box.
The Blaster 2 coil is gonna be an issue b/c I have a HID ballast, OBD-1 ABS pump, and possibly a stock airbox to consider as well. Maybe I won't even mess with coil tuning and just go straight to running the HVC-2 coil.
Later on, I want to switch to a Digital 6+. That'll will for sure have to be placed in-cabin.
Old May 2, 2004 | 07:08 AM
  #33
90turboteg's Avatar
had mine mounted under hood and had problems with moisture, moved it inside under pass. seat, no problems now
Old May 2, 2004 | 04:25 PM
  #34
Default Re: MSD Ignition Question (90turboteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90turboteg &raquo;</TD></TR><TR><TD CLASS="quote">had mine mounted under hood and had problems with moisture, moved it inside under pass. seat, no problems now</TD></TR></TABLE>
Moisture Problems? Arent these things supposed to be made for being under the hood?
Old May 2, 2004 | 11:42 PM
  #35
JDMorgan's Avatar
i dunno my car ran like **** from combo of msd and cai in the rain. i moved the msd to the passanger foot area and the cai to my trunk. dropped the stock intake back on and no problems with that yet,
Old May 3, 2004 | 09:11 AM
  #36
greaseball's Avatar
mine is mounted on the passenger side kick panel. it was a quick and easy install and it is pretty much out of the way. as far as noise goes, if i'm listening to the radio or a cd then i don't even know it's there. good luck.
Old May 9, 2004 | 07:09 PM
  #37
Boofster's Avatar
Default Re: (greaseball)
As requested, close up pics.
One bracket I used was for the ABS fuse box. Not sure where I got the other one. Maybe they were both for the fuse box but I bent them to work. I cut the snaps that held the MSD box together and separated the bottom plate. Then drilled it as needed for the brackets and attached them. Used 4 bolts after that to put the box back together and then bolted the brackets to the car.
The third pic shows where I moved the fuse box. It is only attached by the top screw but holds well.
Don't forget the spliced rubber tube to put over the abs line under the box so it doesn't eat it away when the car vibrates.
Old May 9, 2004 | 07:33 PM
  #38
IN VTEC's Avatar
Both of the brackets are from the ABS relay box...I remember from when I test-fitted everything the way you have it. It's pretty ingenious.
Old May 9, 2004 | 07:59 PM
  #39
TurboTeG4's Avatar
Default Re: MSD Ignition Question (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">I couldn't mount mine on the firewall because of some stuff in the way and I wanted it to sit flush. So I mounted it here:
I stuck a screw in the top left MSD hole into an airbox screw hole (lol) to hold it down. And for the bottom left, I zip tied the hole to a wire plug next to the ABS. It's wedged between my intake and ABS and it's not going anywhere.</TD></TR></TABLE>did something similar but made a custom solid bracket in that location which mounts it.
Old Jul 29, 2004 | 12:14 PM
  #40
speedfrk's Avatar
Default Re: (importdude2000)
I have a 97 integra ls tr and i have an msd 6al, blaster 2 coil and a msd cap and im having some serious wiring problems. cant get a spark. can you help with this.
Old Jul 29, 2004 | 12:19 PM
  #41
speedfrk's Avatar
I have a 97 integra ls tr and an msd 6al with a blast 2 coil and cap and i am having some serious wiring problems. can't get a spark can you help with this.
Old Jul 29, 2004 | 12:26 PM
  #42
importdude2000's Avatar
Default Re: (speedfrk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedfrk &raquo;</TD></TR><TR><TD CLASS="quote">I have a 97 integra ls tr and an msd 6al with a blast 2 coil and cap and i am having some serious wiring problems. can't get a spark can you help with this.</TD></TR></TABLE>
make sure u dont have the coil wires mixed up inside the cap...
i seemed to crossed them and i keep cranking but coudnt start
then i move em over and it started
Old Jul 29, 2004 | 12:28 PM
  #43
speedfrk's Avatar
thanks i will check that. some one else mentioned that to me today as well. my coil was getting really hot but no spark.
Old Jul 29, 2004 | 11:57 PM
  #44
JDMorgan's Avatar
make sure you have a good + and - on the box too i couldnt get good power to my box thru my distribution block so i took it out.
4dooritr
Dec 7, 2008 12:06 PM
turbolude99
Aug 2, 2005 09:26 PM
hatchinprogress
14
Oct 9, 2004 05:03 AM
clemsoncb7
Jul 19, 2004 06:09 PM
mike34655
Aug 19, 2003 05:00 PM
