motor mounts causing loss of power?
is it possible if my mounts are bad that im loosing power? i always wondered cause of all the jerking the motor is doing.
Daisy... Daisy...
Re: motor mounts causing loss of power?
If the mounts are bad enough, the axles may become misaligned and click, make noise, etc.
You can see if there is excess play in the mounts by setting the emergency brake and gently attempting to move the car forward and backwards while someone watches the engine.
my passanger side axle recently began to make weird *** noise, i guess its time to upgrade my mounts haha :D now a motor mount kit there are 3 mounts, is there any other mounts or anything in the engine bay i should also replace if im pulling the engine?
dafreeeze
19
05-14-2013 04:33 PM
