missfire?
Old Mar 22, 2009 | 09:17 PM
dc4b20's Avatar
Default missfire?
would a missfire trigger the check engine light?
Old Mar 22, 2009 | 11:05 PM
99Geeezer's Avatar
Default Re: missfire?
Yes. If There is any fluctuation in crankshaft speed, the ecu can reconize that as a misfire.
Old Mar 23, 2009 | 11:09 AM
dc4b20's Avatar
ok, i just rebuilt my dizzy and now when i am at low rpms my engine kinda feels like it loses power or jerks for a millisecond, and no check engine light comes on. it doesnt do this all the time. i originally thought it could be a missfire. any suggestions?
Old Mar 23, 2009 | 12:45 PM
lexrob's Avatar
incorrect ignition timing
Old Mar 23, 2009 | 03:08 PM
ruskiy's Avatar
Yes. There is a code for misfire(i think it even specifies 2 cylinders). But to throw that it needs to misfire pretty bad, and for a while.
Old Mar 23, 2009 | 05:27 PM
ej_squadron's Avatar
a easy way to check for misfires is with a compression gauge.a good compression would be around 150 psi or so.anything less than 100 could mean bent valves or your piston rings are colapsed.a cyl. leak down test will help u determine if it is the rings or not.if both are good,check ignition or fuel.more so ignition if your car can run.also check your spark plugs and wire.oem wires and plugs are the best to use.make sure they're new or if used in good condition.
Old Mar 23, 2009 | 05:33 PM
mayoforlife2's Avatar
why would you start with a compression check, after he said it started doing it after he rebuild his dis.
Old Mar 23, 2009 | 06:14 PM
dc4b20's Avatar
it only does this every once in a while. not that often and only noticable at low rpms. to me in the drivers seat it kinda felt like a missfire, but no engine light. the motor runs strong and doesnt appear to have a lack of power. the firing order is deffinatly correct. and i dont think a compression test is necessary.
Old Mar 24, 2009 | 10:03 AM
sorry,i thought you had a misfire happening already prior to rebuilding ur distributor.
CUTTERSPOOL
Jul 16, 2009 06:05 AM
sickofitall1113
Jul 31, 2007 12:47 PM
teamitr
Aug 24, 2006 04:28 PM
willyboyK20
Jul 2, 2003 08:10 PM
OptimusPrime2k
Dec 1, 2002 02:55 PM
