map and tps code issue
Old Jun 27, 2014 | 07:28 AM
bmoreb18c1's Avatar
Default map and tps code issue
Please respond if you have any idea;
I changed out the spring on the pulley for my throttle this morning before heading to work and when I started it up the check engine light came on for codes 3 and 7(map and tps).so I figured that something happened to the harness or the intake was unhooked but thats not the case. Also besides revving higher than normal (2.5k @ idle) and getting pretty bad gas mileage I drove 60 miles and it was fine.
Old Jun 27, 2014 | 07:50 AM
B_Swapped93's Avatar
Default Re: map and tps code issue
the map being off WILL screw your gas millage trust me why did you change the pulley ? they never go bad or anything. try putting the old one back.
Old Jun 27, 2014 | 08:34 AM
bmoreb18c1's Avatar
Na the map is not off. I changed the pulley spring because my throttle started to stick at 3k when I let off gas. Not sure what that could have done to turn cel on for map AND tps even though neither ever got unplugged
Old Jun 27, 2014 | 09:04 AM
I meant off as in not reading right and that's when you either adjust the throttle cable or clean out the tb, put the old one back. I can promise you that's the cause, sorry but no one changes tb pulleys
Old Jun 27, 2014 | 09:37 AM
bmoreb18c1's Avatar
Yea maybe "nobody" changes the pulley but I also couldnt find anybody that had the same issue with their throttle getting stuck. Wouldnt you know it fixed the sticking throttle! And I guess nobody changes their pulley when putting on a itr cable
Old Jun 27, 2014 | 09:42 AM
bmoreb18c1's Avatar
So I put it back and its still doing it. I pulled the plug of the map sensor and it runs even worse
Old Jun 27, 2014 | 09:48 AM
So I put it back and its still doing it. I pulled the plug of the map sensor and it runs like crap.
adjust the throttle cable tension ! and yes of course it will plug it back in and reset the ECU.
Old Jun 27, 2014 | 09:57 AM
bmoreb18c1's Avatar
Its tensioned properly...and I was saying that unplugging the map made it worse so I think the map is not to blame. Also why would it cause it to read tps too? Thanks for at least trying to help.
Old Jun 27, 2014 | 10:40 AM
egsleepercivic's Avatar
did you switch the plugs what color are the wires on each
Old Jun 27, 2014 | 01:55 PM
bmoreb18c1's Avatar
Nah I did that when I first started working on integras and in the years since I have heard of many people making that mistake as well. The grey is the map and blue is tps. Its just crazy I cannot figure this out. I am gonna check for a air leak somewhere and test the sensors and maybe take the thermostat ground off and clean the metal up some. I am having a hard time believing both sensors went bad overnight. Thanks for the input though.
radicaled434
Apr 28, 2012 11:34 AM
gnxpro24
Mar 17, 2012 02:25 PM
hotimportcrx
Mar 31, 2008 10:28 AM
Steve@PPD
14
May 18, 2007 06:01 AM
gaydm.accord
Feb 21, 2004 11:12 PM
