Manual conversion
since soo many things swap between civics and integras.....i was wondering if anyone knew if things like pedal, slave cylinder, master cylinder, clutch lines, you know small things like that would swap into my 98 integra, for a manual conversion? i was also wondering could i use a cable transmission?
92-00 civics and 94 to 01 Integras (if i'm not mistaken) use the same Clutch Master Cylinder, The pedal is a direct bolt on, but you'd have to get rid of the auto pedals because the Brake pedal is longer and you'll have clutch/break clearance problems. So you'll need all the pedals off a manual 94 - 01 Teg.
No you can't use a cable tranny. It would require a Cable to hydro conversion..
Any B series Slave cylinders should work from 94 - 01
And as far as a clutch line, just buy a Rywire or ChaseBays for like $60. http://www.rywire.com/catalog/rywire...e8a00985c3b5d1 It's cleaner and you'll have an easier time with the install ..Unless you find a complete line at the junker for cheap
Oh sorry i forgot, you'll also need the complete shift linkage from tranny to shift ****/boot and the plastic center console piece..And if i'm not mistaken, also a manual trans T bracket and Motor mount... and throw some Honda MTF in there. not 10W30 oil..
moosepoop21
14
Jul 30, 2006 09:12 PM
Vincent.
Jun 5, 2006 10:04 PM
