malfunction codes
Old Jun 10, 2005 | 05:44 PM
jizzer671's Avatar
Default malfunction codes
Ok, I tried to see if my 95 gsr was throwing any malfunction codes today. I did everything that i should do, like Have the ignition on the on position and I crossed the black and brown wire together with a paperclip . But didnt get one flash on the check engine light . Can anyone tell me what could possibly be the problem.
Old Jun 10, 2005 | 06:42 PM
HoUTX98GSR's Avatar
Default Re: malfunction codes (valve timer)
was your check engine light on?
Old Jun 10, 2005 | 06:51 PM
Kendall's Avatar
Perhaps a list of symptoms at the very least.
Old Jun 10, 2005 | 06:57 PM
jizzer671's Avatar
no, could that be why? I mean i just wanted to see if it would throw any codes because vtec isnt functioning correctly. But i also found out that my ecu is a p72, and not a p28. Will a 95 gsr perform the same way on a p72 ecu?
Old Jun 10, 2005 | 07:06 PM
Kendall's Avatar
A 95 GSR comes stock with a P72.
Old Jun 10, 2005 | 07:07 PM
Racermech's Avatar
is the vtec working at all??
So the check engine light never came on?? Unless you have a stored code then there is no real reason just to check.
Old Jun 10, 2005 | 08:21 PM
jizzer671's Avatar
Default Re: malfunction codes (Racermech)
heres the thing, I think its the timing , because the skunk2 camgears read that timing is at -4 degrees. never will i mess with the timing because of inexperience but vtec seems to only work really strong in 2nd gear and in 3rd gear, vtec ignites but it doesnt pull. Help me out honda family...
Old Jun 10, 2005 | 08:26 PM
jizzer671's Avatar
engine light is not on at all.
Old Jun 11, 2005 | 06:23 AM
HoUTX98GSR's Avatar
i think your trippin'. if your check engine light is not on, then there wont be a code. and if someone messed with your timing without a dyno, then it could hurt your performance.
Old Jun 12, 2005 | 08:29 PM
jizzer671's Avatar
Default Re: malfunction codes (HoUTX98GSR)
getting timing done on 15th.
2uy
Aug 28, 2005 10:26 PM
hatchinprogress
16
Jan 7, 2005 09:09 AM
urgonnalearn2
Oct 20, 2003 11:54 PM
hatchboy93
14
Apr 23, 2003 10:02 PM
