Major Jerking While Driving PLEASE HELP!
Old Sep 4, 2013 | 07:38 AM
RemedyPersaud's Avatar
Default Major Jerking While Driving PLEASE HELP!
i have a 1995 integra Ls with a GSR b18c1 Swap and the problem im having is the car is idling a little rough, bit of white smoke from the exhaust and also while driving and trying to keep at a consistant speed the car jerks. but if im not on the gas or on its fine only when i try maintain it at one speed. i search many forums and change lots of parts such as
Fuel Regulator
Fuel Pump
Distributor
Injectors
Spark Plugs
ECU
I checked the cat to see if its clogged but its not
I did a compression test the numbers were WAY OFF but for a natural aspirated motor i would assume the numbers would be different.
Im running out of problems and tierd of wasting money my last resource is a Head Gasket but the motor was freshly built about 2 months ago by Me.
Old Sep 4, 2013 | 08:08 AM
Creator's Avatar
Default Re: Major Jerking While Driving PLEASE HELP!
Clutch/transmission related maybe. Not really my area of expertise, just a thought. GL
Old Sep 5, 2013 | 12:07 AM
ef-da-guy's Avatar
i had the same problem on my da, it was that the motor mounts were absolutely trashed, i just did the window weld motor mounts and its was all fixed, drives solid as **** now.
Old Sep 5, 2013 | 06:45 AM
fcm's Avatar
fcm
Old Fart
White smoke would be coolant burning, so HG.
You said you did a compression test, what are the numbers.
Also, when you did the compression test did you do it on a warm engine with TB wide open? 94
Old Sep 6, 2013 | 07:27 PM
I did a Wet compression and here are the numbers and i did it on a warm engine
Cylinder 1 - 195
cylinder 2 - 235
Cylinder 3 - 300
Cylinder 4- 350
there shouldnt be anythig wrong with my transmission worked fine before i did the rebuilt all i change was the clutch NOT the flywheel i used my old one.
Old Sep 6, 2013 | 07:52 PM
B_Swapped93's Avatar
The last 2 numbers are CRAZY high ! 195 to 235 is TOO much of variance(max 25) what about a dry test how much oil was used. From this test I would say rings but do a dry test first and if too much oil was used for the wet one that would throw the test results off.
Old Sep 6, 2013 | 07:59 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
did you test the TPS sensor through it's range looking for a dead spot? they wear out just like a volume control and can definitely cause jerking
Old Sep 7, 2013 | 08:38 AM
fcm's Avatar
fcm
Old Fart
As mentioned, do a dry compression test first then a wet one, I would also try another compression tester. 94
Old Sep 7, 2013 | 09:52 AM
If those numbers are right, you have a blown headgasket or crack between the two cylinders
Old Sep 7, 2013 | 12:36 PM
dc4teg95's Avatar
For the jerking I would check the tps. Had this same issue. Replaced it and set it to specs haven't had a issue since
Old Sep 7, 2013 | 06:22 PM
Ive checked my TPS and everything reading right i even changed my Throttle body cause before i had a s90 so i threw on a Type r one i had laying around to see if it made a difference and it wasn't as bad of a struggle but the problem is still there.
I used a cap full of oil, i did a dry one before i did the wet and the numbers were just as off and not in sequential unfornatly.
im going to pull off the top end and see if it is the head gasket ill keep posted i appreciated all the help
Old Sep 7, 2013 | 06:41 PM
HG won't cause high comp numbers in a wet test like what you're seeing want a 90% pin point answer ? leakdown test save the effort/money for a swap or rebuild. I still highly recommend a more recent dry test before you jump into more lengthy repairs
Old Sep 7, 2013 | 07:10 PM
Jtkdirtbike's Avatar
Not related to compression but I had the same problem and I had some sensors plugged into the wrong spot (i believe the idle air control and evap purge were switched, both two pin connectors) but I have also heard of checking and cleaning egr ports on the intake as well as checking out the egr its self
Old Sep 7, 2013 | 07:18 PM
IIRC from your thread in the civic section you have a H/F engine in your civic right ?. B series doesn't have an EGR valve/related/. his compression on 3/4 cyl is extremely high my tester won't even go past 300 lol. but that's why I said do a dry test may yield something like 120 or less in those CYL's OP does your car burn oil ?
Old Sep 7, 2013 | 07:21 PM
if those numbers are right, you might as well plan on pulling the head anyway, you arent going to waste any time, something is seriously wrong internally
Old Sep 8, 2013 | 08:17 AM
fcm's Avatar
fcm
Old Fart
It is because the numbers are so high, I recommend doing the compression test(s) again, first a dry then a wet, using another compression gauge. 94
Old Sep 8, 2013 | 01:41 PM
dc4teg95's Avatar
Could check the map sensor my friends ls would do this also and his was the map sensor. Sounds sensor related to me
Old Sep 8, 2013 | 07:15 PM
Oops, my bad... but still check sensors (look up wire colors and make sure the match up with the sensor) I couldnt even take the emmissions test until mine were put in the correct order
Old Sep 9, 2013 | 10:07 AM
will do a dry then wet test again and for any sensors ive doubled checked and tested to see if missed wired but its all correct.. the engine was running before perfectly fine no problems.. i did the swap 2 months ago and this is now recently occurring.
ill also look into the leak down test
jdm91integ
Jun 27, 2014 03:00 PM
Blue00Si
Oct 26, 2012 01:06 PM
LSTurbo23
Sep 26, 2012 07:07 PM
TurboSpoolinInside
Jun 19, 2010 11:25 AM
dev
Mar 30, 2008 05:20 AM
