Maintenance Scheduling
Old Jul 30, 2003 | 04:31 PM
WhOIZiT's Avatar
Default Maintenance Scheduling
i dont have the owners manual, so im not sure the times for maintenance and what type of maintenance there are. anybody can post a link? or at least post the jizz ( ) of it. im at 42k and the maintenance light has came on and im wondering, wtf should i check into or replace?
Old Jul 30, 2003 | 05:26 PM
xteg95's Avatar
Default Re: Maintenance Scheduling (Turbonium)
so long as you do your usual maintence yourself just turn the light off...its right under the dash above where your right knee would be.
Old Jul 31, 2003 | 04:09 AM
JimBlake's Avatar
If you tell us what year & model you have maybe we can answer...
For my '95 GS-R...
7500 miles engine oil & filter - I do this every 4k & rotate my tires too
every 30k - I do this every 20k:
change transmission oil
adjust valve lash & inspect timing belt
change air filter
every 60k
change spark plugs (GS-R has Pt plugs)
every 90k
change timing belt & waterpump
every 2 years whatever mileage
change antifreeze
change & flush brake fluid (& clutch fluid)
Old Jul 31, 2003 | 06:20 PM
WhOIZiT's Avatar
i have 01 gsr integ.
Old Jul 31, 2003 | 06:40 PM
xteg95's Avatar
Default Re: (Turbonium)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbonium &raquo;</TD></TR><TR><TD CLASS="quote">i have 01 gsr integ. </TD></TR></TABLE>
http://www.edmunds.com/mainten...+++Go++++
Old Jul 31, 2003 | 08:12 PM
GirlyGS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbonium &raquo;</TD></TR><TR><TD CLASS="quote">i dont have the owners manual, so im not sure the times for maintenance and what type of maintenance there are. anybody can post a link? or at least post the jizz ( ) of it. im at 42k and the maintenance light has came on and im wondering, wtf should i check into or replace?</TD></TR></TABLE>
i am not sure what year your car is, but mine is a 2000. here is what my owners manual say for 42k change your oil and filter, replace your coolant, inspect from and rear brakes, replace brake fluid, check parking break adjustment, visually inspect tie rods ends, steering gear box, and boots; suspension components, driveshaft boots, brake hoses (including ABS, all fluid levels and condition of fluids, cooling system hoses and connections, exhaust system, finally but not least fuel lines and connections. hope this helps...
Snowwhitecoupe
Oct 21, 2011 05:13 PM
RolandDeschain
Honda Civic (2001 - 2005)
Sep 6, 2011 10:51 AM
lv6l
Jan 4, 2009 01:10 PM
MacH
Apr 11, 2008 09:18 AM
froger
Jun 3, 2005 08:58 PM
