Ls-vtech with B16?
Old Feb 8, 2007 | 04:47 PM
USJM's Avatar
Default Ls-vtech with B16 tranny, s4c?
Any body running this?
Modified by USJM at 6:09 PM 2/8/2007
Old Feb 8, 2007 | 05:12 PM
BlangBlangTEG-93''s Avatar
Default Re: Ls-vtech with B16? (USJM)
I am in the process of building a Ls/Vtec turboed right now. I am using a B18a1 block and a B16a3 head, all fully built of course. I did alot of research on all of the b series engines and it seems like the b16a is one of the best flowing heads.
Old Feb 8, 2007 | 06:10 PM
ejmatzell's Avatar
Default Re: Ls-vtech with B16 tranny, s4c? (USJM)
vtec
Old Feb 8, 2007 | 11:06 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: Ls-vtech with B16 tranny, s4c? (ejmatzell)
Do a little search on this, lots of people are running ls/vtec and I'm sure plenty are using b16 trannys.
BTW what is your question? If people are running ls/v?
Old Feb 9, 2007 | 06:37 AM
redlsvtec4door's Avatar
i had a built lsvtec running cams and 12.5 comp and a b16 tranny. the highway was alittle painful but damn that bitch got down 0-80 hell 0-135 (top speed) and dont listen to people saying you cant rev a b18b block mine saw 8500 rpm atleast 10 times a day and a couple of really bad mishifts to 10000.
Old Feb 9, 2007 | 11:16 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: Ls-vtech with B16 tranny, s4c? (redlsvtec4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlsvtec4door &raquo;</TD></TR><TR><TD CLASS="quote">i had a built lsvtec running cams and 12.5 comp and a b16 tranny. the highway was alittle painful but damn that bitch got down 0-80 hell 0-135 (top speed) and dont listen to people saying you cant rev a b18b block mine saw 8500 rpm atleast 10 times a day and a couple of really bad mishifts to 10000.</TD></TR></TABLE>
I'm another LSV guy. Walking proof that a LSV done properly WILL last. 11.5 cr and GSR trans. 5th gear sucks, but on the street....man, it's a killer. I only spun mine to 8500rpm on the track and 7k daily. USE GOOD RINGS. 10K rpm is NOT a good idea. Safely depending on use of ARP bolts or not and if you're going forged internals you might spin to 9k....MAYBE.
Good luck.
Mr. Chainsaw
Oct 16, 2008 06:48 AM
lastpunkinline
May 13, 2006 06:21 PM
eg6T
Nov 24, 2004 07:14 PM
joboost13
Oct 3, 2004 08:39 AM
