LS/vtec vs b16
Old May 13, 2006 | 03:54 PM
lastpunkinline's Avatar
Default LS/vtec vs b16
Ok this kinda has to do with the topic but, when you make an Ls/vtec do you have to get it tuned in order to drive it because of the vtec engaging on a non vtec block? and if you have a b16 short block and put a vtec head on it, could you just drive it w/o tuning it??? These might be some stupid questions but im a stupid person.
Old May 13, 2006 | 03:55 PM
lVlemphizStylez's Avatar
Default Re: LS/vtec vs b16 (lastpunkinline)
yes you need to tune the ls vtec...if you put a b16 head on a b16 block...you shouldnt have to get it tuned...itll run off the factory ecu...cause its essentially...a factory setup
Old May 13, 2006 | 05:45 PM
Default Re: LS/vtec vs b16 (lVlemphizStylez)
It is a b16 head but its not stock. It has CTR cams, valves and retainers. and little stuff like DC sports cam gears(if that matters) It was originally on my turbo motor but I want to just get a b16 running for now until I get a new turbo kit.
Old May 13, 2006 | 06:21 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lastpunkinline &raquo;</TD></TR><TR><TD CLASS="quote">It is a b16 head but its not stock. It has CTR cams, valves and retainers. and little stuff like DC sports cam gears(if that matters) It was originally on my turbo motor but I want to just get a b16 running for now until I get a new turbo kit.</TD></TR></TABLE>
the cam gears would definately make a difference and need to be tuned properly with the motor
odz-fab
May 24, 2013 02:04 PM
97integraLS911
Jan 15, 2008 08:14 PM
parfait2882
Dec 12, 2006 03:05 PM
Methane2k2
Nov 21, 2004 05:45 PM
