ls/vtec turbo problems
Old Apr 24, 2007 | 08:21 PM
rdssk8rcs1's Avatar
Default ls/vtec turbo problems
I just recently took my integra out of the garage for the new season and started driving it again. I did all the preperation of running it again and took it easy during the re-break in. Anyway now that it has some wear in and i started running it hard again vtec is not engaging. I know there are tons of threads on this but i searched and could not find anything that helped me with my problem.
The car is a 2001 ls/vtec turbo. With a 00 gsr head and the wiring harness adapter to plug in the obd I p28 ecu. I did work on teh car a bit while it was garaged without starting it. The car was not started for about 5 months.
Does anyone have an idea of what my problem can be?
Old Apr 24, 2007 | 10:24 PM
deadline's Avatar
maybe just change out ecu...with another..to see if vtec kicks in..
Old Apr 25, 2007 | 03:20 AM
rdssk8rcs1's Avatar
Default Re: (deadline)
Thats not a bad idea but i would ned to either buy or find another one socketed with hondata.
Anyother ideas?
Old Apr 25, 2007 | 06:24 AM
DC2 Mang's Avatar
Default Re: (rdssk8rcs1)
there are multipale reasons why vtec will not engage
low water temp
low oil level
low oil pressure
speed you are traveling
also check your signal wire, mine came loose before and I couldnt figure out why mine would not engage
Old Apr 25, 2007 | 08:11 AM
rdssk8rcs1's Avatar
Default Re: (DC2 Mang)
Thanks i will check those things again. I know the water temp is fine and the oil evel and pressure is good. But i will double check the signal wire
Old Apr 25, 2007 | 08:14 AM
rdssk8rcs1's Avatar
any other weird reasons it wont engage?
Old Apr 25, 2007 | 11:05 AM
Rikter's Avatar
Are you sure it's not engaging? I know it's a bit of stupid question to ask but I know on my lsvtec turbo I no longer feel the vtec engagement let alone hear it.
It was only until we put it on the dyno and saw it on a graph as well as hooked up a pressuage gauge to the head/solenoid itself that we saw it engaging.
-Rik
Old Apr 25, 2007 | 11:11 AM
97gsrki's Avatar
Default Re: (Rikter)
did you take your head off? if so there is a little, i dont know what to call it exactly, but like a small dowel pin. it goes underneath the middle cam cap holder thinger haha. anyways, without that vtec will not engage.
Old Apr 25, 2007 | 05:09 PM
rdssk8rcs1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rikter &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure it's not engaging? I know it's a bit of stupid question to ask but I know on my lsvtec turbo I no longer feel the vtec engagement let alone hear it.
-Rik</TD></TR></TABLE>
No i understand the reason for your question. And i do agree with you, i know exactly what you are talking about. But the two big reasons for me not thinking it is engaging because the car is a lot slower than it was before the winter, like a very noticeable about. And it stops pulling after like 6500 rpm. It used to pull hard all the way to redline almost making me not even want to shift sometimes but now once it gets up high there isnt any point in waiting to redline just because it is no longer pulling or making any power
Old Apr 25, 2007 | 05:11 PM
rdssk8rcs1's Avatar
Default Re: ls/vtec turbo problems (rdssk8rcs1)
i am also going to try to go to radio shack tomarrow to buy some necessay adapters and cables to hook my mac to my hondata to be certain if it is engaging or not.
Old Apr 25, 2007 | 09:10 PM
rdssk8rcs1's Avatar
Any other clues?
Old Apr 27, 2007 | 09:55 PM
Spoon84's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdssk8rcs1 &raquo;</TD></TR><TR><TD CLASS="quote">Any other clues?</TD></TR></TABLE>
Umm have you check the solenoid? Use a test light to see if there is signal going to it. If there is then you might need a new solenoid. Also check to see if you hear it clicking over inside the solenoid. Check your grounds.
SickEg973
Engine Management and Tuning
Aug 15, 2013 01:14 AM
HONDABOND0255
Jan 8, 2008 07:58 PM
boosted k20
Jul 21, 2005 07:15 PM
evsproject94
Jun 6, 2005 02:01 PM
theEGkid
Apr 20, 2005 07:56 AM
