LS VTEC PROBLEM!
Old Dec 25, 2007 | 06:08 AM
HONDABOND0255's Avatar
Default LS VTEC PROBLEM!
i recently built my 1992 b18a b16a2 head. p30 ecu chipped- p30 dizzy- I used the golden eagle kit, had a machine shop plug the oil galley, brand new vtec solenoid and cant get vtec to work??? i've checked the wiring, oil pressure, ect! need some honda tech help.
Old Dec 25, 2007 | 06:32 AM
awdgsx96's Avatar
Default Re: LS VTEC PROBLEM! (HONDABOND0255)
Has the car been warmed up?
Try double checking the wiring.
And how do you know vtec isn't engaging?
Old Dec 25, 2007 | 09:26 AM
Default Re: LS VTEC PROBLEM! (awdgsx96)
I took it to get tuned, and the car not only dyno'd at 112 whp, it just revs out like
a normal ls no pull, no high cam switch point, no difference in sound. My last hatch was a ls vtec and vtec was abruptly noticable. the car was operating temp on dyno. anything else you can think of other then the wiring
Old Dec 25, 2007 | 09:42 AM
xthekidx's Avatar
are you getting a CEL? is vtec even engaging? you should be pulling close to 160 at a minimum.
what bottom end are you running? stock ls?
Old Dec 25, 2007 | 05:38 PM
Default Re: LS VTEC PROBLEM! (xthekidx)
Built bottom end, ctr pistons arp rod bolts knife edged crank. No vtec is not engaging and yes i should be pulling well into the 160's easy. the problem is the vtec solenoid is showing 12v at activation but engine doesn't switch over to high cam. what could be the problem?
Old Dec 25, 2007 | 06:01 PM
awdgsx96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDABOND0255 &raquo;</TD></TR><TR><TD CLASS="quote">Built bottom end, ctr pistons arp rod bolts knife edged crank. No vtec is not engaging and yes i should be pulling well into the 160's easy. the problem is the vtec solenoid is showing 12v at activation but engine doesn't switch over to high cam. what could be the problem?</TD></TR></TABLE>
I don't know the electronic parts of vtec, is it supposed to engage at 12v or something? Is the engine grounded properly from the valve cover? I don't know if it will help, but it might be worth trying
Old Dec 25, 2007 | 06:03 PM
bad chip in ECU??
You try another ECu and see if vTEC POPS??
Old Dec 25, 2007 | 06:05 PM
TomsDC's Avatar
when i did my ls/vtec mine did the same thing. i found out i didnt have enough oil pressure. dont know if thats your problem but thought it might help. good luck.
Old Dec 25, 2007 | 07:47 PM
DAneronimo's Avatar
you have a bad vtec solenoid....if the wire going into it has 12 volts; vtec should be working....if its not, the solenoid is bad
Old Jan 8, 2008 | 07:54 PM
DAneronimo's Avatar
we should feel used......people signin' up just so we can fix their cars for them lol
Old Jan 8, 2008 | 07:58 PM
HONDRETTI's Avatar
Default Re: (DAneronimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDABOND0255 &raquo;</TD></TR><TR><TD CLASS="quote">i recently built my 1992 b18a b16a2 head. p30 ecu chipped- p30 dizzy- I used the golden eagle kit, had a machine shop plug the oil galley, brand new vtec solenoid and cant get vtec to work??? i've checked the wiring, oil pressure, ect! need some honda tech help. </TD></TR></TABLE>
start with checking for codes you should find your answer there, and let us know
also check the FAQ thread at the top of the forum
Ricey_Bricey
Feb 27, 2009 05:22 PM
Ricey_Bricey
Feb 21, 2009 09:18 AM
ericstypeR27
Dec 19, 2008 06:39 PM
theEGkid
Apr 20, 2005 07:56 AM
