LS teg with IAC problems HELP!!!!!!!
Old Jan 24, 2005 | 02:32 PM
Thrillhouse's Avatar
Default LS teg with IAC problems HELP!!!!!!!
Ok I have replaced the IAC, and checked for vacuum leaks using the carb spray method, and checked the plugs to see if they are on wrong. Everything matches up so now Im very very very lost, I dont know what else could cause it. What else is in the IAC circuit that could cause this? Do any of you guys that have this same problem happen to run a hondata intake manifold gasket? thats the only other aftermarket thing I have on my car.
Old Jan 24, 2005 | 03:58 PM
Default Re: LS teg with IAC problems HELP!!!!!!! (Thrillhouse)
I know there are other people with this problem, cmon guys help me out
Old Jan 24, 2005 | 04:39 PM
xscape's Avatar
What year is your car?
have you tried opening the FITV (if you have one) and screwing the middle part back in?
did the job for me
Old Jan 24, 2005 | 05:10 PM
Default Re: LS teg with IAC problems HELP!!!!!!! (xscape)
mine is a 99 I dont think it has an FITV if it does Im not sure where or what it is. Let me know
Old Jan 24, 2005 | 05:12 PM
xscape's Avatar
nah, 99 doesnt have an FITV..
Old Jan 25, 2005 | 04:52 AM
I dont know if this helps but it also makes a very low deep but loud humming noise when I tap the gas, sounds to be intake related but only started to happen after the IAC sel started to throw.
Old Jan 26, 2005 | 01:53 PM
ok I loosened the throttle cable a little bit and it seems to be less noticable. Im kinda stuck on what to hunt for next.....
Mar 30, 2006 10:16 AM
ITR.#1446
Dec 9, 2004 09:26 AM
the0ne
Dec 6, 2004 06:34 PM
MugenGTR
Apr 14, 2002 11:26 PM
Geeboy
Jan 8, 2002 10:58 AM
