LS headers same as Type R???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZR4DR »</TD></TR><TR><TD CLASS="quote">They are different. Just like the LS and GSR headers are different.</TD></TR></TABLE>
so typeR wont fit onto LS? i heard they fit?? jus asking...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wizzards581 »</TD></TR><TR><TD CLASS="quote">
so typeR wont fit onto LS? i heard they fit?? jus asking...</TD></TR></TABLE>
They'll fit. Actually a GSR header will work on a LS, but with modification to the cat or the b-pipe.
The ITR header are the same exact lenght just like the Ls header, and i am almost 100% postive that they both have the same bolt pattern, the only difference is the collectors size, JDM ITR= 2.5 and Ls= 2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sickintegra4u2nv »</TD></TR><TR><TD CLASS="quote">it will bolt on the head but u would have to worry bout reachin the cat</TD></TR></TABLE>
Incorrect. The ITR and LS/RS/GS stock exhaust manifolds are completely interchangable. An ITR manifold will bolt on to an LS without no modifications whatsoever, and likewise an LS manifold will bolt directly to an ITR. A number of manufacturers even list their ITR and LS headers as the same part number.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Incorrect. The ITR and LS/RS/GS stock exhaust manifolds are completely interchangable. An ITR manifold will bolt on to an LS without no modifications whatsoever, and likewise an LS manifold will bolt directly to an ITR. A number of manufacturers even list their ITR and LS headers as the same part number. </TD></TR></TABLE>
^ This is the closest thing to a correct answer so far.
He just has to add the 00-01 GSR header to that he's set.
The following:
94-01 LS/SE/GS/RS
00-01 GSR
All ITR
headers are all direct replacements for each other in terms of fit. Primary and secondary tube sizing is different (won't affect fit, but will affect performance) as well as the merge angles of the tubing.
HTH
The following:
94-01 LS/SE/GS/RS
00-01 GSR
All ITR
HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by obd1_jdm_gsr »</TD></TR><TR><TD CLASS="quote">since when did integras have headers? i thought we have just a header</TD></TR></TABLE>
When you start talking about more than 1 (aka plural) you have to add the "s" chief.
Modified by BlueTeg at 5:05 PM 10/6/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueTeg »</TD></TR><TR><TD CLASS="quote">^ This is the closest thing to a correct answer so far.
I would have, but the original question inquired specifically about the LS and ITR manifolds.
</TD></TR></TABLE>I would have, but the original question inquired specifically about the LS and ITR manifolds.
There's no problems at all when putting a type R header in an LS. It fits perfectly, I have one installed in my 94 teg rs. I'm actually selling if anybody is interested.
