LS header on GSR?
Are you that lazy?
First result from a google search "gsr header on ls"
http://www.team-integra.net/fo...=3677
You will need to shorten the exhaust B-pipe by approximately 4.5", and you'll also need to plug up one of the O2 bungs (either the one in the header or the one in the cat).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">You will need to shorten the exhaust B-pipe by approximately 4.5", and you'll also need to plug up one of the O2 bungs (either the one in the header or the one in the cat). </TD></TR></TABLE>
I'm not using a cat.
Will I run into any problems shortening it?
OEM header into flex pipe
Flex pipe to resonator (red arrow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">No, it doesn't look like you'll have a problem shortening the pipe. </TD></TR></TABLE>
Ok cool. So i just need to move the flex pipe back a few inches is all?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECth1s »</TD></TR><TR><TD CLASS="quote">you can make any b-series header to fit any b-series motor, just takes custom work and welding.</TD></TR></TABLE>
obviously, that's why i asked what exactly needs to be done.
